R34s...please!
NS2500
well i thought I may as well post some pics of mine over the years..
Back in 09 at the SAU NSW Show and Shine
Then I got bored with my old wheels and got some new ones.
Then I gots me some 33GTR brembos with 345mm BIOT 2 piece front rotors
Next on the line was a full respray as some parts had been faded since it arrived from japland, Treated my new paint to some Craft Square carbon mirrors.
This was its first outing since the respray, took it down to Shepparton to do DECA with SAU VIC.. Dont I look smashing :P
Then with the help of my good friend Eric and God_Speed for letting me poke around with his genuine Nismo tail lights we made our own for the standard tail light housings
I'm missing additions like the bucket seat, harness and other crap but those are all the photos I could find since losing my external HDD with all my pics and videos over the years..
Now its back to doing silly things like this when im not racing properly
These look amazing... DIY tutorial/group buy (we send lights, you assemble) lol?
Hey Tom no lol at all - Dave is setting up to do retrofits to your existing R34 tails if you want the Nismo-style LEDs. I believe all you do is provide your old tails and you get them back with all the LEDs and requisite control units etc; for a fee :)
Bolt on Nismo bits look awesome.
Inspired by Terry_GT-R34's immaculate N1.
Man you got all of that done in no time at all! New rims, Nismo front bar, V.spec II bonnet, side skirts, and a detail!! Looks amazing mate!
Btw, I'm normally pretty good at guessing what cars are from a little snippet, but what is that parked next to the 34? Looks like something American (GM)?
We got played! :)
Sorry, didnt mean to give you guys a bum steer. LOL
I found the original pic on my hard drive last night and had a quick play with the plate / rims / colours.
It is most likely the route I'd go if I were to mod.
Looked quite nice so thought i'd share.
The matching restricted parking markings caught my eye too!
lol
I won't know what to look at between yours Chris and Simon's (n11smo)
You're both meticulous & you both have spectacular BsB specimens
Paul (Moelders) is right up there too.
The 3 of you need to photoshoot with Matt Everingham!
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
