R34s...please!
NS2500
We actually know another Steve, of Steve's Auto Barn at blackheath; he owns a BB with white LMGT4s and plates ORSUM. Great looking car, but been ages since Ive seen it.
Here it is!
And here's Chris's. Yeah it's nice. :)
Edited by God_speed
Maclarenf1, As promised. Only had two more pics -
Will have them one day once the engine side is sorted....
Silver LMGT4 looks really nice on a Black R34 GTR with Nismo Skirts and Spats with VS-2 bonnet. (not huge fan of the Nismo bonnet mind you)
This has being my inspiration for few years, which led to me buying my car... Not quite there yet !!!..
i can see why that black gtr has been your inspiration - it looks fantastic with wide open spoke wheels!
are u guys familiar with nz rips racing 'sparks stealth bomber'!
Edited by Marko R1
^ That looks very similar to God_Speed's car. Fantastic.
Maclarenf1, I'm assuming your car is black. Do you have any pics of it as is?
Pretty standard V-Spec [had a V-spec 2 badge, first thing to come off :) - hate fake badges] - had it for about 1.5 years now, ideally want to do around 1 track day maybe 3 month or so..once the engine is up to that, will think about the exterior...
Runs HKS-Fcon Vpro currently with Stage 1 mods (Only Turbo's to do - getting GT-SS / -9 at the end of the year and she is done)
Also came with some odd bits from japan too like 4 wheel drive controller, modified Diffs, heavy clutch, camber arms, oil cooler, NOT normal FINS on the rear diffuser and a mother of strut bar :)
Currently Runs 239.9 AWKW with 1 Bar + Cam gears on high and stock boost on Low (HKS EBC).
http://imageshack.us/photo/my-images/193/qldraceway.jpg/
http://img844.imageshack.us/img844/313/img1591n.jpg
http://img34.imageshack.us/img34/9316/img1554sd.jpg
Very Envious of you'r car - i am not very good in washing or buffing IMO...
Marko R1, is this the lady we speak of?
http://imageshack.us...qldraceway.jpg/
http://img844.images...13/img1591n.jpg
http://img34.imagesh...6/img1554sd.jpg
Looks fantastic maclarenf1, thanks for sharing.
Thanks for the kind words. I'm no pro, but if you ever think I may be able to help with some buffing tips - just give me a yell.
M-spec inspired seats sound good, black leather i assume.
Very Nice!
...and some person is privileged to have both VS2 & R-Tune bonnets...
The bayside on Gt4's would look a lot better in the metal than in those photos. In this vid the mines BSB looks incredibly clean on the Gt4's
, pity they are tough to find in that colour size etc; these days.
    • You need the kit turbo taipan has shown you because that manifold ia designed have side feed injectors
    • @johnnysr22 did you end up installing the little screen thingy and did it work ?>
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
