R34s...please!
NS2500
too much blue haha...
lets see some other colours ha... i was going to post some of reds and other rare colours, but struggled abit.
heres another of mine from a fellow forum member taken on the putty road run, i like this shot.
Not enough yellow.
Looking fantastic as always mate, keep the pics coming please.
Got to have a little bit of blue in there -
haha cheers mate, nice pics of the red, blue and white... i like it.
i would like to see some of a yellow one next to some other colours... dont think i have seen any pics side by side?...
heres another of mine from the same photographer above.
Hey mate, this is what I have at the moment.
Nice one mate, think I'm happy I went black instead of white with the yellow..
Phil, Thanks for uploading the pics mate :-)
GTR-34A, cars looking amazing, lovin the Yellow and black theme.... drool.... more,more,more plzzzz.
Cheers mate, don't have many more good pics unfortunately.. Will take more next time I go out
Definately mate, better constrast. You know I think it looks fantastic.
We should get some pics of both of our girls together.
Yea a previous owner actually painted the stock 34r wheels white on mine, but I bought the car without these... I actually have a pic of the car with the white vspecii bonnet onit before it got painted yellow.. Actually looked kind of good ha.
Would love to get some pics of them together mate, next time I'm in sydney with the car I might have to stop in... And if for some reason your going through newcastle with the car, let me know
Dan, is your wing blade painted white?
That carbon wing blade would set it off. Fingers crossed it'll work.
White R34 GTR wheels would look interesting, have pics?
Black n White themes always work well.
The fact that I opted for black skirts n pods was more dictated by black rear view mirrors.
Yes a black c/f rear wing blade is also tempting.
Congrats on the white R34 above!!!
    • You need the kit turbo taipan has shown you because that manifold ia designed have side feed injectors
    • @johnnysr22 did you end up installing the little screen thingy and did it work ?>
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
