My partner wouldnt do the sexy pose for me.. and someone had to do it.
Cut out my suggestive facial expression to keep this thread work safe.
Damn, I'm in love with your car. There's something just soo right about a clean, aesthetically stock BB gtr
Thanks Chris :)
They aren't bad rims Marko, not exactly the lightest wheels going around but they do look quite nice IMO
I'm thinking about changing to matte black Enkei RPF1's 18x9.5 +15 all around...haven't seen too many 34 GTT's with RPF1's.
Thoughts or recommendations for other wheel upgrades?
how much effort do you think would be required to make an 18x9.5 +15 fit. im looking for new wheels but am wanting good traction as well as offset, so id be looking for something like a 255 on a 9.5 +20 but i fear it would take to much camber/guard work to get them to fit properly. anyone running a 255 on the front of a 34 gtt? otherwise id look at a decent 235 on a 9 +20, but does anyone know of anything comparable to say an xd9 in this offset? cheers
@Spark, nice yellow 34! Is that the 'DIY Lip' I see used all round, even on the skirts?? :P
Was wondering what they'd look like on the skirts if it really is so haha.
On another note, too many GTR's in this thread...
... making me jealous!
thanks for the kind words guys, makes me feel proud of my canary mobile :)
definitely is the El Cheapo DIY Lip kit all round lol turned out okay but im currently in the process of getting together a kit for it
so YAY or NAY for black RPF1's?
ahhbee: would take a bit and money to go into the front guards to make a 18x9.5 +15 fit with 255 tyres...a 235- sized tyre however, makes it a fair bit easier to fit.
I have a good mate with a GTT who is running 18x9.5 +15 all round with 235/40/18 tyres. Rolled guards, camber arms (mainly to go between track/street) and the slight stretched tyre make them fit quite nicely. I'd simply spend more on a nice, sticky 235 than a ok-ish 255 and be happy with that
This will answer your question :)
Matt black would really set it off!
I like these rims because they are very well priced and different to what you would expect to see on a skyline. If I had an r34, I'd run these wheels.
I was even thinking of buying a set for my 32 but they don't suit the car as much with the high detail and intricate design.
index-15.php
Edited by Marko R1
    • Yeah. I believe the fear of annealing the alloy and weakening it, Every online discussion has someone saying it's bad and potentially a risk when powder coating forged wheels.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
