Awesome work guys! Love coming in here and checking out the pics!
We have a decent cruise on the 21st with 8-10 R34's attending, will hopefully get the boys to do some group shots :yes:
More details mate, is there a thread for this?
looks like a fair amount of work has been done under the hood... quick specs?
ah ok.... lil run down list is far too long lol
tomei poncams
arp head bolt set up
full race engineered head block by JHH engineering (port polish the whole 9 yards)
wiseco forgiez
forged bottom end
hks t04s turbo
arc cold air intake box
greddy intake plenum
rc 810cc engineering injectors - fuel rail
sard 52mm (i think ) external wastegate
top mount mani
greddy radiator & intercooler
hypertune 90mm throttle boddy
saard fuel pressure reg
arc surge tank wallbro fuel pump
everything exhaust, mani , intake ceramic coated
full Apexi el2 gauges oil pressure,temp , water temp boost control unit
Apexi avcr & rsm
vi-pec ecu
Os Giken twin plate clutch
fly wheel machined and lightened
2 way differential
slotted brake rotors front and rear
endless break pads
upgrade prop shaft balanced etc
hks ssq
Thats a quik run down list is a stack of a4 pages of receipts lol
Basicly have built this as tough as money can build a 25 det without stroking.
yea 'MONEY PIT' would prob be the words I would use.... but love it so much . 18000kms on clock parts done just over 6000k's now.
If your in queensland and going on the Charity run on the 4th of Nov im heading there so if you are wanting a nosey to perhaps get some tips on upgrades more then happy to unload the knowledge learnt so far.
Running 400bhp everyday tune 548 on second tune.
car has been built for 1000hp but still need to upgrade turbo, intercooler and modify fuel set up to run it.
Will definately be at power cruise 2013 with these figures running.
Anything else you may want to know pm me or post up here.
Cheers
Looks good mate, does this have a ridiculous list of mods and was for sale in the past few months????
Thanks Mate.
Na was never advertised i dont think, But Yeah i have owned it for about 4 weeks now. Bought it in canberra of a mates cousin. Has a crap load of work done to it with Nitto 2.7 stroker. Goes in on monday for a tune, should make around the 650 to 700 mark i am hoping, but we will see what happens. Motor is built for around 700kw so i was told by the guys that built it.
Edited by Sonny1986
That sounds insane man, well done. Unfortunately I'm far from Brisbane, but you should head down to Goulbourn for SAU Nationals in November coz it's going to be HUGE :thumbsup:
Yea man definately good potential to come out of it but like we all know time and money, then more money .....
Definately was considering heading to Sau Nats but changing country and car and more work financially cant make it..
Got a Uras front lip ages ago & finally got it on the car as well as a set of 18x9 Enkei RP02's.
ive been looking at one of the uras lips for my gtt of recent, just wondering does it smooth back in in front of the wheels or stay flared out.
cheers
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
