I'm sure it will mate! Your 34R is the best I've seen in yellow. I got one set of stickers previous to those but I didn't like the outline, so found the red set which were perfect
Cheers mate. Yea ny wheels are te37sl but I didn't like the red with the yellow, so will see how they work out. Will post pics once there on.
Dang son, very well done. What are the specs on your wheel fitment?
Also, how did you tint the reverse lights?? DIY?
Cheers Tom,
19x9.5 +12 all around, front and rear guards are both rolled to flatten the lip and pulled out a few mm.
Reverse lights are tinted using a gloss black tint film (not like window tint) i stock, as were the rear indicators which i now have precut pieces to suit 34 tail light indicators. The beauty of it is when you throw it in reverse or put on your indicators they are still clear as day, almost no reduction in brightness with the tint film on.
Cheers Tom,
Sounds the goods Stephen, I just bought some cst zero-1 hyper in 18x9.5 + 15 all around, so the fitment should be very similar to yours :yes: . What tyre sizes are you running, and do you get any scrubbing on full lock?
Considering you run a graphic business, I'm guessing you can supply the tint film?
PM me details if this is the case :thanks:
Ah very nice,
Tyres are 235/35/19 up front and 265/30/19 rear.
With the front plastic guard liners removed there is almost no scrubbing on full lock.
I'm thinking of adding camber arms to give it just a little neg camber and also hopefully help it tuck more when leaning into a corner/going down a large dip, as if i corner too hard it will scrub a little on i believe the guard. Also going down a dip really fast which naturally compresses the coilovers tends to cause a little scrape.
Will send you a PM regarding the tint film.
Some pics I dug up off my hard drives.
Love em!!
Hey thats my car :) , geez long time since that photo taken some changes since then. ( wheels, bonnet :) , some slight damage to lower lip :( )
Glad it made it onto the must keep photos lol
Its actually a Fluro Orange, (Which you prob still might not like lol) the shitty iPhone Camera does not even show you how bright these are, thought they would be something a bit different for summer.
They were originally a white rim and I Plastic Dipped them.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
