So what are the differences between a vspec2 and nur?
In Addition to Terry's post:
A Nur comes factory with a N1 Engine which has:
N1 Twin Turbo's (Ball Bearing / Steel Internals) As Terry has mentioned.
N1 Cylinder Block (Thicker Cylinder Walls / Enhanced Water Cooling Channels to increase flow / OEM Crank Shaft Balanced at a higher level)
N1 Pistons / Piston Rings / Conrods (All Balanced)
N1 Oil Pump
N1 Water Pump
N1 Exhaust Manifold
N1 Air Hose (Cold - Air Duct)
Yeah Mat, it has a real tough stance - nice photo :thumbsup:
Thanks Matt (There really is too many Mats/Matts in this thread lol)
Will get it detailed up and do some shots of the engine bay and car etc... This was just on a Sunday cruise and we found a nice spot with a railway bridge in the background, will visit it again!!!
Clean, Mat. I like the emotions
Thanks Clint, they were in the silver colour but needed repairs so i did them the same colour as my engine and plenum etc.... The engine is probably the best looking part of the car ;)
Very tidy looking 34 mate. :)
Appreciate it, a LOT of work has gone into this thing over the past 3 years and the results are finally showing!
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
