Hi flow turbos, an exhaust, injectors and a tune was pretty much it. The best part was knowing you could take it to the track and knowing it wouldn't blow up
Thats awesome! I new it would of been a few simple mods and off you go.
Yeah marko there dry sumped. 12 litres i think the 965 has
my uncles got a 993 turbo sitting in his garage. bought it new, hasn't been driven for years. Only got 6000ks on it over 17 years.
I want to buy it off him soooo badly
make sure u make it known to him if he ever sells the car that u want it...I did the same with my uncle and now I have his car :)
Whats done to it... very nice 34...
nismo part's:
  • exhaust
  • coilovers
  • suspension link's
  • carbon fibre wing flap & pillar garnish
  • intercooler & piping
  • front bar
  • oil cooler
  • inlet duct
  • radiator cap
  • gear knob
  • wheels & nut's
  • instument cluster
  • led tail lights
  • oil cap
Mines chip, Hks F-con & evc,5 zigen clutchless gear change system & led reverse light.
Motor is still standard on 1bar of boost,236kw's on the gt auto dynopack.thanks Iron chef.
Edited by I gotta R34gtr v-spec
Its nice to see my old 965 still getting around :yes:
Really wow thats nuts! you would be the best person to compare the 965 to the 34 gtr
Paul how does the clutchless gear change system work? Never heard of one of those before
I'am still trying to work it out myself Dimi,this box is under the drivers seatpost-93096-0-97203100-1342351817_thumb.jpg
this is under the parcel shelf in the bootpost-93096-0-24627900-1342351848_thumb.jpg
this switch seems to operate it on the dashpost-93096-0-47451100-1342351857_thumb.jpg
switch to the right and a buzzer sounds,hold to the left and the motor looses rev's. :unsure:
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
