R34s...please!
NS2500
Love that ksr gtr! although i think it might look better with a white or carbon kevlar wing stand
Hey guys will a 19x10.5 +22 fill the guards more than a 18x9.5 +12 or is it about the same? After something that will sit more flush with the guards on the gtr
Also have a look at the blue and white pic together and what seems to look like the same front bar the white one has these two bumps/fangs below the gtr badge. Is it only the original ones that have that and the ones without are fake?
The "fangs" are normal and standard on all GTR front bars as far as I am aware aside for the "Nismo" style bars, could be wrong though
i had 19x10.5 +22 on my car, it filled the guards ok, but i was after something more aggressive. youve got to be aware that wide tyres will fill the guard as much as wide wheels, so putting on wide wheels with skinner tyres still wont fill the guards much if you know what i mean. im pretty sure with 19s 275 is about as wide as you can go with out guard work or no sidewall...
i just changed to 18x10.5 +15 and fitted 295 tyres on... looks perfect imo, fills the guards nicely (tucks in slightly at the back towards the top only because im running a couple of degress camber) and the tyres are flush and chunky.
hope that helps..
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
