Hey,
Thanks For the coments appreciate it.
The strut brace is Auto Select it's a heavy weight of the options avaliable but certinaly does the job and looks killer! I do have some other pics of it but there still on the camera will load em up later this is all i have atm.. Still a few more parts in boxes in the shed to go in next week can't wait!!!
- GoldZilla Yeah the badge really seals the deal i think, old school haha... It is unbelievable the difference the front fenders and bonnet make to the car really does make it look angry lol..
Thanks again
Kingy
that red r34 is pure sex!
Thanks mate :sick:
When I got it, it was silver, stock and damaged...as it´s been hit by a tractor when the previous owner had it.
But since it was the VERY FIRST street legal german R34 GTR and by the time I bought it still the only one with registration, I wanted to make it something special :whoops:
Hey,
Thanks again
Kingy
Very sexy!
Thanks dude. sizes are 17x9+22 with 255/40 all round. Lol, got too excited, just slapped them on and took pics totally forgot about tyre shine. Whole car is in need of a good wash.
Edited by john-e boi
Hey man, great work with the wheels, the offset is tough as!
only my opinion, but perhaps when you're over the bronze, maybe get them re-done in gunmetal grey or gloss black, as it will go real nice with your bonnet, spoiler stands and center section of your front bar - it will definitely set it off nicely with the white paint
great work, many of us can only dream of a set of wheels like yours for our rides =)
Edited by squareznboxez
Thanks for the comments guys. Was originally going to get them sprayed matt black. But the bronze has grown on me heaps. We'll see what happens later on I guess.
18x9.5+12..mmmm interesting lol. How much you want for them? With tyres? Condition? Might be abit too aggressive for my liking though. Just lowered my fronts abit more so tyres sits just under the car and it looks pretty good I reckon. Going to be hard to sit at that height when wheels sticks out like this unless guard work and/or heaps of camber with stretched tyres. Also 18x9.5+12 all round
Picture is from another SAU member
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
