im in the process of getting moneis together so i can get bigger cams (not overly big) and valve springs to go with. :rofl: hopefully will get a nice amount of power then............so doesnt make the car seem like its "all show and no go"
not that i really care what people think on that topic
damn it sounds like ur real serious about pumping as much out of that NA as possible. have you ever thought of getting a turbO? not that theres anything wrong with ur NA, but the benefits would be alot more!!!
like i said though its a hot looking car.
yes i am quiets serious about keeping her n/a!!!!!!!
i do agree that yes the benefits of a turbo are there.........but i dont want to be like everyone else who has a turbo......
i have a plan that i am sticking too..........
do the cam shafts, valve springs, bearings too! aftermarket ecu
and see what happens! may end up being a rebuild!
  • 1 month later...
Hi guys, the weather was nice over the weekend so me and the missus took some shots in front of adelaide oval and the city east end.
Very nice mate. The stripe suits it well too. You've done the right thing with the caps as 34 wheels look feral without the centre caps on. I had a set of 34 GTT wheels on mine and they look very very tacky without them :blush:
Very nice mate. The stripe suits it well too. You've done the right thing with the caps as 34 wheels look feral without the centre caps on. I had a set of 34 GTT wheels on mine and they look very very tacky without them :)
Thanks mate, yeah caps stay on :) Unless it's like on an S14 or something or S15, it seems to go well with those cars without caps for some reason.
Hey Howie nice 34, Hey you have the GTR style rear bar dont you? Do u have ne idea if it would go with a impul kit? (impul front n sides with a GTR style rear bar) Cause yours seems to blend in nice
Cheers Tom, it's the factory option from the nismo catalogue, not quite GTR style. I've thought about getting just the impul front bar for the car, but wasn't sure about keeping the skirts, the rear though would probably look fine with it.
hey peoples my 34 is to leave Japan sometime this month i hope.....
anyway heres a few pics of it in Japan
very nice ride.love those rims.
hope you gona take that wing off....
please take that wing off.
Edited by fob2nv
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
