Awesome pics Craig. It's surreal seeing so many 34 GTRs together like that! More pics of the N1?
Pics of Terry's N1 were taken with an iPhone and edited on the phone using Snapseed - definitely recommend this app.
i cehcked out the app - it will support android 4.0 ice cream sandwich soon which is what i have!
What the...?
I had to go and look that up, haha. But yeah it's a great little tool, costs a few bucks but worth it IMO
If any of you R34 Owners are after a bit of carbon "look/frp carbon overlay"
-> http://www.skylinesaustralia.com/forums/topic/390222-carbon-goods-for-r32r33r34/page__st__20__gopid__6221104#entry6221104
More buyers, cheaper for us all.
what size rims are on that white r34? they look like polished work meisters - beautiful!
Pretty sure they're 20's x 10.5 but not sure of the offset. I'm sure one of the WA guys knows....
That blue one is mint.
Do you have stand still pics of the white 34 with SLs... and more pics of the white 34 with meisters HOT...(front on if possible)
This is all I got, next time we catch up I'll get some more for you :thumbsup:
Which one is yours Craig?
Matt, I was driving at the time so no photos of mine! I've got a stocky MNP2 V-Spec, but it's nowhere near the pristine condition of the other cars!
Edit: actually first photo on previous page top right - it looks black though.
Edited by 32godzilla
Give yourself and your 34 some credit man! Any other pics of yours?
Very nice Terry - glad to see you enjoying the new car.
Us westerners caught up again today, here's some pics from the day, we had a total of 8 x 34 GTRs including 4 x Nurs, 1 x V-Spec N1 and the rest V-Specs!! I'm hoping to get 12 x 34 GTRs together for the next one :thumbsup:
Fantastic pics, thanks for sharing.
Yeah I did a little research myself and yes it does look very similar but I believe d34throw was a v-spec ii? Also the pics I saw showed red after market seats and gauges everywhere so unless Chris changed it back it's a different car. Huy and I will get the lowdown next time we see him. It certainly is a stunning example.
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
