Love that ksr gtr! although i think it might look better with a white or carbon kevlar wing stand
Hey guys will a 19x10.5 +22 fill the guards more than a 18x9.5 +12 or is it about the same? After something that will sit more flush with the guards on the gtr
Also have a look at the blue and white pic together and what seems to look like the same front bar the white one has these two bumps/fangs below the gtr badge. Is it only the original ones that have that and the ones without are fake?
The "fangs" are normal and standard on all GTR front bars as far as I am aware aside for the "Nismo" style bars, could be wrong though
i had 19x10.5 +22 on my car, it filled the guards ok, but i was after something more aggressive. youve got to be aware that wide tyres will fill the guard as much as wide wheels, so putting on wide wheels with skinner tyres still wont fill the guards much if you know what i mean. im pretty sure with 19s 275 is about as wide as you can go with out guard work or no sidewall...
i just changed to 18x10.5 +15 and fitted 295 tyres on... looks perfect imo, fills the guards nicely (tucks in slightly at the back towards the top only because im running a couple of degress camber) and the tyres are flush and chunky.
hope that helps..
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
