Also on this note, it is one of my PET PEEVES seeing for sale ads for R34 GTRs where the owner advertises a 'full z-tune bodykit' just because they have a set of Nismo/replica side skirts and rear pods!! WHAT ABOUT THE FRONT BAR, GUARDS AND HOOD?!?! How are those skirts/pods specific to the z-tune and how does only having those make it a '"full kit"??!? Some GTR owners know very little about GTRs.....
I saw the for sale ad. - it made me lol at the mention of a "z-tune bodykit"
LOL I've seen it 100 times. I don't know if people do it intentionally to BS their add and make their cars seem worth more, or because they genuinely don't know that those rear pods and side skirts came out long before the Z-tune, they are not specific to the Z-tune nor do they comprise a "full z-tune kit". Maybe they can't see that the front bars are so clearly different also???
^^^^^ WOW :woot:
We caught up with Adam from JEM on the weekend as he had a surprise, he found me a street name with my last name which was awesome haha..... Got a few pics but nothing special..... Car was filthy AGAIN :P
Will return when the fences are gone and do a decent shot when its all cleaned up too lol
^in fairness, i do see a lot of S-tune bars mistaken for Z-tune bars
Hmmm they look completely different though. One has additional air vents adjacent to the front indicators, while the other doesn't have these and has a blended middle-lip section (ie.all 1 piece vs. front bar in 3 sections including the diffuser)
Hey Dim as others have said, the front bars with the 2 'Nissan' style bumps in the front grille are replicas. The original GTR front bar from Nissan has these, though both the Nismo Ver.1 and Nismo Z-tune front bars do not have these. Some replicas (or most actually) of the Nismo Z-tune front bar don't have those bumps and are therefore 'identical' replicas, though others such as those from Bodyform Aero do have those bumps. I know for fact that the entire kit on the KSR GTR was made by Peter at Bodyform Aero. Props to him and his top notch work! - I think with the 2 bumps in the grille it is a more individual look and is a good combination of elements from the standard Nissan bar and the more aggressive styling from the the Nismo Z-tune bar.
Also, I run 19 x 10 + 20 with no scrub on full lock and I'm using 275/30R19s. I did however get a bit of touching when I had 275/35s on - my car was sitting quite low before however but once i jacked it up a bit and swapped the tyres I had/have no issues at all (it's now just sitting on 10cm from the ground). In terms of worse handling you're right. It isn't that bad for street use (you've sat in my car so you'd know!!) but its definitely rougher than 18s with more rubber. I regret selling my 18s because now I need another set (this time wider) for the track.
Cheers man thanks for the info!
^ Yeah Iron Mike, when I was looking for an s-tune bar I had so many people say "yeah I've got one of them".
I would ask for pics, and what they provided were pictures of a z-tune bar hahaha.
Sooo I went with a cruise front bar just to completely throw everyone off ;)
Edited by TM7GTR
You mean the Nismo Front Bar..? Not S-Tune...
Stock Front Bar
Nismo Front Bar
Nismo Z-Tune Front Bar
+1
The Nismo Z-Tune "Full" Body Kit just re-uses the Nismo Side Skirts and Rear Pods.
In addition to new Front Bar / Guards / Bonnet / Rear Fenders.
My bad - didnt read last post properly.
While on the topic, I am curious to know how much the z-tune guards add to the width?
It seems weird that the original rears would already be wide enough for the z-tune kit to only add a lip on the arch while adding a wider front fender.
Excellent Jamie this is spot on. It's worth noting too however that the '"Nismo front bar" from above is sometimes also called the Nismo ver.1 front bar (and also the "s-tune" front bar as it appeared on the s1 and s2 models that were prototyped before the release of the z-tune), while the z-tune bar is also sometimes called the Nismo ver.2 front bar. You will see this a lot in Japanese publications and auction/sales info. There is definitely a difference between them though (and quite a significant difference too), which is why it sh!ts me when someone only gets the Nismo skirts and pods and claims they have a "full z-tune bodykit" :I
  • Like 1
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
