didn't know this thread existed.... i guess i should put a pic up :D
hopefully getting some SLR type pics soon... in the mean time...
All genuine East Bear ;)
not sure if i need a spoiler, i'm leaning more towards YES, than No
It needs a badge in the middle of the front grille, but i'm not sure about a GTS-R badge, even though the kit is legit.... something about the R....
Sorry to quote the pics and all but people need to see that again, thats hot!
Perfect GTT I reckon, dont put a r badge on it, thats trying to hard.
Neil
My contribution :D
wow... looks so mean.. esp with that bodykit and fmic.. love the rims too.. so stealth! ..
Where did you take the pics? Looks like something from Need 4 Speed Underground.. lol
Edited by missusR34GT
Thanks for the nice comments ppl's, it was a long road to get here :( Forged, car is looking hot as ever :)
nah Howie, it's my original black R34 under all that East Bear :P
I um'ed and ahh'ed about finishing of the rest of the kit, but thought what they hey... something a bit different out there :) I *think* i'm still the only one in Oz with the full kit, but i'm not sure.
Not sure what to do with the spoiler at this stage...
DECIM8, i thought you were going wide body kit mate?
i was then i had a look at cars with wide bodies and in almost all could see screw holes :) im going to talk to peter again and see wat he recommends.:( in the mean time im making it a weapon mechanically :P the car looks great we'll see how i go with the wide body and go from there. Wish powerplay would hurry the fudge up
All genuine East Bear :)
No spoiler man, that looks fkn hot as is
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
