Looks good.
Tommy Kaira Aspects.. interior shots please :thumbsup: and engine.
Interior is pretty standard FOR THE TIME BEING!!
After i finish with the interior pics will be posted up
Also thinking about a Z-Tune Carbon Bonnet any suggestions or could anyone PHOTO SHOP one against my car??
Thanks
Howie, was the GTS-R badge $20 from powerplay??
hmmm... my car needs something in that space.... maybe that'll do the trick.... i guess it's a legit badge as it is the GTS-R kit :thumbsup:
is your grille/mesh stuff the factory stuff? I'm trying to find some OEM GTR mesh/grille, but not having much luck. Everything about the East Bear kit was absolute quality...except the mesh :(
They sell the GTS-R East Bear Badges at Century city in springvale and their other store in footscray.(They are proper east bear product)
and yes i too have been hunting everywhere with no luck for the oem mesh.
hey GUYs and GIRLs,
Last year i decided to keep my Tommy Kaira R34 GTR!
But from the day i bought it i had my own modification that i wanted to do !
So i have lately been building it to my specs,
Carbon Fibre front V-Spec front lip
Nismo side skirts and rear pods
Ganador Carbon mirrors,
Nismo Carbon rear wing lip,
Nismo Carbon A-pillar garnish,
White TE37,
Ap Racing 6 pot pistons
Nismo N1 fron bar cut outs,
Nismo Carbon intercooler surrounding
Nismo Clear Side indicators
Nismo Clear front bar indicators
Tell me what u think
Thanks
PIC R NOW UP GUS!!!!
Those white TE37's go so well with the Bayside Blue :thumbsup:
Isn't the interior of the Tommy Kaira different?
I remember the R33 GT-R Tommy Kaira was. Or something.
The 2 front seats are different and the dash is electronic
But besides that, nothing is different
Im wanting to get 2 front BRIDE seats in blue.
I think that will look yummy!!
R-spec, awesome looking car mate, i think the black and red rims suit way better. If it was me though, id remove that rear bar, and replace with a standard, or gtr or something other than the nismo one :)
then id add eye lids and replace the wing :( ((( to me the r34 just doesnt look the same from behind without the wing IMO)))
still awesome car, keep it up :huh:
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
