:( all :)
i actually like the rear bar, only bit i dont like is the little fake mesh thing on the bottom.
i prefer the wingless look so i'm keeping it as is. to help smoothen the rear a bit i removed the rear wiper which i think helps.
Dead set sexy mate! Have I said before how much I want your bonnet? :D
lol i was looking at a pic of your car last night and saw your de-badged bootlid so i went and took mine off too :) need to clean off the glue shit
get me a similar style bonnet in c/f and i'll give you mine :huh:
oh and i'm getting the lips on the rims polished/chromed next week. although i dont mind the burgundy...
Hey Guys, these are my 2 R34 GTR'S , White One is For Sale , Keeping the Silver One Have Big Big Plans For It ...Will keep you all posted on Upgrades ....
Both nice, though I do prefer the silver one lol.... and umm just a tad jealous two gtr's and your on your p's...... :domokun:
Phew phew phew!! Looking hot Daniel! Btw ... should look at getting a pair of philips silvervision amber blinkers to go with your nismo clear front indicators.
MRGTR911... lovely GTR's mate! You're making us all jealous.
Thanx Guys Appreciate it, My next Step on Silver R34 Is Z Tune Bonnet , Ganador Mirrors , Carbon Pillars , Carbon Eye Lids , Do you guys Think i should Get the Z Tune bonnet In Carbon Fibre Colour or keep it The Same Silver Colour ?
I want to get your ideas first ?
I actually like the white one better because i dont like the silver front bar that much.
What is it about the Z Tune front bar you dont Like ? You telling me You will Prefer a Say a V SPEC Front Bar Over a Z tune Front Bar ??
Anyone else prefer a standard front bar over A Z Tune front bar ?
Yeah, just my personal liking.
Just the ztune bar is open and "square" shaped. Where as the standard one in my eyes is more round and just matches.
Thats why i like th white better, but the colour is also prefered :domokun: as you can see.
What about Silver Carbon Fibre? thats what I am thinking when I eventually get down to doing the vent bonnet that way it almost looks stock but without the weight.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
