Why won't my wife pose like that in front of my 34? LOL
Nice ride mate!
LoL thanx mate, though i would lov to get a lip like you have. yours is hot as!! :(
Nice,if you don't mind me asking but what height is your wing? and where did you pick your wing up from ?
thanks,
Cheers
David
the height of my wing sits at about 19 - 20 cm, danno where its from was on the car when i got it
That silver GT-T looks good that low without the wing, normally they look funny, but low and wingless does it :)
Cheers. Sadly it couldnt stay that low. My brand new rainsports now have a nice extra grove in them thanks to my guard. Extra water channel perhaps?
Looked so good dropped hard but in the end it had to come up :P
Well i guess its now or never....lol :P
ah this is hawt!, glad i saw these, now i know what my white 34 is gona look like or similar to when i get around to some rims, im wanting black gt-c's with silver lip :D
your pics just confirmed my wanting for them!
Thanks man its pretty dirty. The intercooler is Cooling-Pro Stealth Intercooler kit from Just Jap
http://www.skylinesaustralia.com/forums/Co...er-t209304.html
Easy to install not much moding needed to fit it, its all in the forum above
First of all, hi to everyone!
Im quite new to these fourms... mostly been on GTR.co.uk fourms seeing that there is a lack of GTR owners in NZ, but seeing that im moving to AUS early next year, and taking my GTR with me ;) i thought id post up some pics of my car! But since ive only owned this since last november i thinik i gotta keep it for 2 years. So help out with my import issues and info below! Thanks!! Anyways the pics....
http://www.skylinesaustralia.com/forums/Br...nd-t230962.html
Edited by Addicted2Boost
^^^ Awesome!!
How do you go with the carbon bonnet? Any dramas with defects from the cops?? Also, if it rains, does the engine get drenched with water?
Did u just drill your number plate into the front bar?? Im thinking of moving mine up a bit from the stock position
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
