I have a pair of HKS GT2530's forsale. Made 380rwkw at 22psi
One is in as new condition, no shaft play (was rebuilt and stamped earlier this year by GCG)
The other has worn bearings which in turn has slightly damaged the turbine, housings and compressor are ok.
Includes a pair of Adjustable HKS actuators
PM
or
0413023669
Matt
Edited by BOOSTD
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
