This turbo made 350rwhp on 17psi boost on 3 litre v6 turbo (vg30det )polished 5.0 compressor .ceramic coated 0.96 exhaust. 53mm front wheel, 63mm exhaust wheel.Has done 200km and 3 dyno sessions work(like new still) plus K&N filter, 500hp fuel pump, silicon reducer,turbonetics boost controller,oil delivery line and fittings, plus 6 x 550cc rx7 injectors (series 5 ) just serviced ready to go. (100hp each) $1200 the lot
[email protected] :action-smiley-069:
https://www.sau.com.au/forums/topic/146649-450hp-turbo-and-550cc-injectors-x-6/
RB20 injector rail has to be changed to accept 14mm o-ring style injectors (instead of 11mm type which is what the rb20 has) the rx-7 injectors part number is 195500-2020 (i think) to use a low impedacnce injectors you would have to use a resistor pack from a gtr (http://www.skylinesaustralia.com/forums/index.php?showtopic=62674)
No, wrong, the injector is a 11mm(13mm with o-ring) so it would fit into the rail. And also Im sure the injector is a high impedance one, being a factory injector, I will check tonight as my multi meter has just gone flat(need to get some batteries)you did get the part number correct :laugh:
0421862864 for further detailes
Edited by zdream
No, wrong, the injector is a 11mm(13mm with o-ring) so it would fit into the rail. And also Im sure the injector is a high impedance one, being a factory injector, I will check tonight as my multi meter has just gone flat(need to get some batteries)you did get the part number correct :ninja:
yes, they are high impeadance injectors :P
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
