hey all, this may be something basic, but all off a sudden, now when i press my Accelerator it feels heavier, like i need to push it harder, i did only notice this when i got a heavey duty clutch, but that was 6 months ago and im use to it now, i never installed a new flywheel, and i know i have to replce my tailshalf soon, but from what i know, it should cause a shaking if tailshaft is about to die and is sliping..
my turbo and forced induction parts seem ok, and sounds good while spooling,. the car goes when i put my foot down, dont feel any lag or delay, just feels harder to press the Accelerator, i have tryed this on a cold and hot night, still same effect, is this possbile?, or any idea what it may be would be awseome. thanx
https://www.sau.com.au/forums/topic/146676-feels-heavier-to-press-accelerator/
Check the cable moves freely, check the throttle body, check that nothing is jamming against the pedal under the dash and that the mounts are ok and moving freely.
The weight of the pedal is unrelated to anything else on the car.
sweet. thanx for the tips, ima try this in the morning... :P
a new clutch sorta makes your accelerator pedal harder i found, need to give it a little more of a push due to a hevey duty clutch.. but now it feels like i need to push a little more heaveir, i thought it was my tires, so i checked the psi and was fine, but still feels like its doing this.. feels weird
Edited by seriesII
yeah, niether did i, maby im wrong, but yeah, a couple of guys who work on my car, say that once you install a heavey duty clutch you need to give it a little more gas as the clutch is more weight then the stock one.. maby im wrong?, but sounds right, and when i got in a stock skyline with a heavey clutch i had to give alot more gas due to a heavier clutch.. might not notice the difference in clutch if your car has a fair bit of power. but i could be wrong hey :P
It could be a sticky accelerator cable, try removing the cable from the throttle body accelerator drum and working it with no other load. If it feels tight then thats your problem. You can use something like spray grease or wd40 to free it up.
The clutch pedal and accelerator pedal are completely unrelated. The only thing that can get heavier with a new heavy duty clutch is the clutch pedal. All i can think of is maybe they were meaning that with a heavier clutch you need to give it more revs to stop it from stalling?? Who knows...
there is no way the clutch can affect the throttle cable. i'd say that the cable is either squashed from the install of the clutch, starting to fray inside the casing, or just got some gunk making it sticky.
and you shouldn't have to give it more gas to accelerate. you may have to give it more gas to launch the car as the heavier clutch won't slip as much, resulting in bogging it down, but once you are going there is no difference. and a heavier clutch doesn't really weigh any more than a stock clutch. it just has stiffer springs. it will weigh a fraction more due to the extra material needed to get the stiffer springs, but it is a tiny amount.
when they talk about the weights of clutches they mean the clamp weight. how hard the pressure plate pushes the clutch plate against the flywheel.
mad082: hey, thanx for clearing that up with me.. i felt it today. it was weird.. felt light at one stage, then a couple second later, after my foot was on, felt heavey again.. still checking for things that may be catching.. thanx for the help tho..
Yer... I think when they said "you need to give it more gas", they meant you had to get the revvs up a bit higher so you don't stall when the clutch grabs. It's harder to make a button clutch "slip" when you start moving.
Definately get the cable sorted. Even disconnect it from the pedal, then have someone inspect the engine-bay side, while you pull on it. Disconnect the throttle body side and do the reverse. If that snaps while driving, you could be stranded somewhere.
While the cable is off the throttle, check that you can open the throttle by hand, and that it's smooth. The spring is not progressive rate from memory. It should be pretty linear all the way through.
Absolute crap.
Mines easy as all hell to slip.
Button clutch, 1250 clamp load. Barely needs any throttle to get it moving. Rolls off the mark with basically no more then 1000RPM...
Drives like stock really... Well, for me anyway.
Just need skill + practice to slip a button clutch.
When you say 1250 i assume your talking in pounds? Thats light as, mine is 3000 pounds (1800lbs stock). Its also a single plate from Jim berry and its marginally heavier than stock to use. Its not all about diaphram tension.
After hearing your pedal changes you should look at the hydraulics to make sure either the slave cylinder or master cylinder arent leaking or in the case of the slave corroded and sticky...
Absolute crap.
Heh... well.. My R32 GTR mate installed a Jim Berry special, and there's something like 2mm of play before it completely clamps up! Even the dyno operators stalled it when they moved it from the driveway onto the rollers. It's MUCH more fussy than my heavy duty Daikin clutch.
But anyway... back to the topic of accelerator pedals, not clutch pedals eh? :O
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
