ur goin all out on this parcel shelf lol.
i knocked mine over in like 2 hrs, didnt even think about putting foam or anything.
the cut on 9mm is steeper but everything fits in nice and snug. i onli used 9mm coz i had it lying around but even if i was to go and buy it, i wud still use 9mm. just seems more solid, and since im going to have subs, i figure the heavier the thing is, the less it'll vibrate
i ditched all the stock clips and all that and just screwed it in with self tappers from under it
i suck with a jigsaw so the wood was pretty sh*t...but after u cover it with carpet ($12 for 1mx2.5m from spotlight) u dont even see the wobbly cuts lol.
  • Replies 40
Posted Images
hows it goin all, yer i recently did my parcel shelf + speakers, (bought my r33 5 days ago) i found that 6mm mdf fits neatest. lets you keep the covering for the windscreen wiper motor...
yep the cover fits nicely ontop of the 6mm mdf, but decided to rotor the area down to 2.5mm(orig thickness) so i can use the original clips on the cover.
yer that sounds like a good idea ay... hadnt thought of that... how did you mount down the shelf?? mines actually in two halfs, i cut it straight across just to the left of the windscreen wiper motor, if that makes any sense? :-s
The original parcel shelf had 6 black clips at the very end which clipped onto metal holes located right up at the bottom of the window. I rivetted the clips onto my new shelf and suprisingly clip on like the original shelf.
Located near the front of the shelf (closest to the seats) were 6 plastic clips which clipped into holes in the chassis. Seeing as there were holes in the chassis for these clips, i just place a bolt through the shelf/metal and added a bolt. The screws pop out in the boot so just stick your head in there and you should see the bolts and just add a nut.
Going to place the left over carpet between shelf/chassis and that shelf aint moving anywhere :/.
Hope that helps
Cheers
Pics for anyone interested!
Put some strong glue on the shelf and put carpet ontop, folded over edges and stapled in.
Put in air-vents and used hot-glue gun to stick them in.
Should have final pics at end of week :happy:
post-10032-1167389994.jpg post-10032-1167390029.jpg post-10032-1167390079.jpg
Cheers
Wheres the best place to get new carpet for the parcel shelf? Spotlight???
I went to bunnings. They had a bunch of auto interior carpet. Which were pretty expensive. $18 a metre, needed around 1.3m lol
Spotlight sounds like a good place to hunt for.
Keep us updated on the spotlight search
Cheers
- Patrick
  • 2 years later...
redoing my rear shelf and a lot more now, fiberglass reshape, LED lighting, new 2 way component speakers for rear fill, black micro-suede , Audio control logo glowing artwork for shows..lol
the complete car build is being photo documented for posting in a few spots.link to be provided in 6 weeks
  • 2 years later...
Ive taken my parcel shelf out, Was so so so fustrating getting this prick out.
Ive traced on to 6mm MDF. Im ready to lay carpet now. and foam on the back.
This is proovig to be alot more expensive then to just buy a sub. or some fitting speakers.
Im thinking of jsut buying a stock Parcel shelf again. Though im sure my what are the size that fit. My rockfords are not 6x9's But i was told on intall they will not fit.....
Spotlight doesnt sell that kind of carpet only thick rugs and a bit of house carpet
Any auto trimmers , autobarn sell it , think its about 35 a metre at autobarn for the proper speaker box carpet unbacked so you can pull it tight , dont use thick foam under it , it will get floppy in the heat and looks like. Cat bed
Clark sells thin open cell white foam , 6 mm i think it is maybe less use that , cost about 5 bucks to do the parcel shelf , they have other stuff but dont
Be tempted some of it is poor for cars and dies in UV here
Use proper contact cement ot better is a high strength high temp spray glue , all the ither stuff fails in the sun and heat
Dont glue the foam down and carpet , only glue the foam to carpet or foam to wood , otherwise it will bunch up and look horrible
Few tricls , and glue the carpet under the board edge trim with razor blade :-) done
3m glue or similar in a can , autobarn , car paint shops sell it too
And some bunnings do
Wurthers is good
And they sell a mexican one here cfr the name but it works better then 3m and bigger can for less , but causes cancer in mice haha
Foam was going on the underside for a more snug fit and take some vibrations out, What size speakers are a direct fit to the R33 parcel shelf? or is the issue the depth of the speaker cone?
Done my Boot floor in 9mm MDF, Plus glued the orginial floppy one on the bottom just so i have the square foam foot rests ect.
haha holy thread revival! cheers for the comments :)
5yrs after completion, it is still in the car!
Review:
- The carpet fabric has come off, as in if i put my hand on the carpet it will be covered in strands. Probably the sun has caused it to fail?
- My vents didnt stick to the carpet, they have lifted. Stronger glue would have to be used next time.
- I didnt put any foam underneath the shelf, might cause rattling issue once a sub is in the boot :/
Hopefully this DIY will serve for another 5 years :P
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
