ur goin all out on this parcel shelf lol.
i knocked mine over in like 2 hrs, didnt even think about putting foam or anything.
the cut on 9mm is steeper but everything fits in nice and snug. i onli used 9mm coz i had it lying around but even if i was to go and buy it, i wud still use 9mm. just seems more solid, and since im going to have subs, i figure the heavier the thing is, the less it'll vibrate
i ditched all the stock clips and all that and just screwed it in with self tappers from under it
i suck with a jigsaw so the wood was pretty sh*t...but after u cover it with carpet ($12 for 1mx2.5m from spotlight) u dont even see the wobbly cuts lol.
  • Replies 40
Posted Images
hows it goin all, yer i recently did my parcel shelf + speakers, (bought my r33 5 days ago) i found that 6mm mdf fits neatest. lets you keep the covering for the windscreen wiper motor...
yep the cover fits nicely ontop of the 6mm mdf, but decided to rotor the area down to 2.5mm(orig thickness) so i can use the original clips on the cover.
yer that sounds like a good idea ay... hadnt thought of that... how did you mount down the shelf?? mines actually in two halfs, i cut it straight across just to the left of the windscreen wiper motor, if that makes any sense? :-s
The original parcel shelf had 6 black clips at the very end which clipped onto metal holes located right up at the bottom of the window. I rivetted the clips onto my new shelf and suprisingly clip on like the original shelf.
Located near the front of the shelf (closest to the seats) were 6 plastic clips which clipped into holes in the chassis. Seeing as there were holes in the chassis for these clips, i just place a bolt through the shelf/metal and added a bolt. The screws pop out in the boot so just stick your head in there and you should see the bolts and just add a nut.
Going to place the left over carpet between shelf/chassis and that shelf aint moving anywhere :/.
Hope that helps
Cheers
Pics for anyone interested!
Put some strong glue on the shelf and put carpet ontop, folded over edges and stapled in.
Put in air-vents and used hot-glue gun to stick them in.
Should have final pics at end of week :happy:
post-10032-1167389994.jpg post-10032-1167390029.jpg post-10032-1167390079.jpg
Cheers
Wheres the best place to get new carpet for the parcel shelf? Spotlight???
I went to bunnings. They had a bunch of auto interior carpet. Which were pretty expensive. $18 a metre, needed around 1.3m lol
Spotlight sounds like a good place to hunt for.
Keep us updated on the spotlight search
Cheers
- Patrick
  • 2 years later...
redoing my rear shelf and a lot more now, fiberglass reshape, LED lighting, new 2 way component speakers for rear fill, black micro-suede , Audio control logo glowing artwork for shows..lol
the complete car build is being photo documented for posting in a few spots.link to be provided in 6 weeks
  • 2 years later...
Ive taken my parcel shelf out, Was so so so fustrating getting this prick out.
Ive traced on to 6mm MDF. Im ready to lay carpet now. and foam on the back.
This is proovig to be alot more expensive then to just buy a sub. or some fitting speakers.
Im thinking of jsut buying a stock Parcel shelf again. Though im sure my what are the size that fit. My rockfords are not 6x9's But i was told on intall they will not fit.....
Spotlight doesnt sell that kind of carpet only thick rugs and a bit of house carpet
Any auto trimmers , autobarn sell it , think its about 35 a metre at autobarn for the proper speaker box carpet unbacked so you can pull it tight , dont use thick foam under it , it will get floppy in the heat and looks like. Cat bed
Clark sells thin open cell white foam , 6 mm i think it is maybe less use that , cost about 5 bucks to do the parcel shelf , they have other stuff but dont
Be tempted some of it is poor for cars and dies in UV here
Use proper contact cement ot better is a high strength high temp spray glue , all the ither stuff fails in the sun and heat
Dont glue the foam down and carpet , only glue the foam to carpet or foam to wood , otherwise it will bunch up and look horrible
Few tricls , and glue the carpet under the board edge trim with razor blade :-) done
3m glue or similar in a can , autobarn , car paint shops sell it too
And some bunnings do
Wurthers is good
And they sell a mexican one here cfr the name but it works better then 3m and bigger can for less , but causes cancer in mice haha
Foam was going on the underside for a more snug fit and take some vibrations out, What size speakers are a direct fit to the R33 parcel shelf? or is the issue the depth of the speaker cone?
Done my Boot floor in 9mm MDF, Plus glued the orginial floppy one on the bottom just so i have the square foam foot rests ect.
haha holy thread revival! cheers for the comments :)
5yrs after completion, it is still in the car!
Review:
- The carpet fabric has come off, as in if i put my hand on the carpet it will be covered in strands. Probably the sun has caused it to fail?
- My vents didnt stick to the carpet, they have lifted. Stronger glue would have to be used next time.
- I didnt put any foam underneath the shelf, might cause rattling issue once a sub is in the boot :/
Hopefully this DIY will serve for another 5 years :P
    • Jamie does know his stuff , you might just want to give them a call and ask - here is their FB page  -  https://www.facebook.com/profile.php/?id=100063506985512 - you will find the number to call them on.
    • Do you think the guys in Penrith are install the E85 Kit?
    • Thanks Pac!   I will reach out to them!
    • Yes, but 2 things of the top of my head, 1. Legalities of nitrous on a street car. 2. No chop chop. I fully understand that there's much cheaper ways to make power, and whilst a wet 50 shot is fairly cheap to install, bottle fills are expensive, and bottles always need to be refilled, and nitrous also has its own inherent issues with reliability, and tuning, from my experience of others using nitrous, it doesn't take alot to lunch a engine real quick if something goes slightly wrong when spraying, if I wanted a big chunk of additional powers, a spooly boy would make alot more sense, disregarding the additional engineering, supporting mods and other logistical issues of sticking a spooly boy on a car that came naturally aspirated from factory  In the end I'm not racing for sheep stations, and I don't really care if people make more power, or are faster than me, or spend less, or more than me, the only thing the car needs to do is drive around and make me smile, which it is doing now Really, I just want a shiny new intake to look at when I'm cleaning the engine bay, and of course, some more induction doorts, and maybe even that 5kw for that elusive 200hp cherry on top that I might get If the FAB9 intake plenum, TB and air filter box thing doesn't eventuate for whatever reason, Plasmaman do one, not as fancy looking, and a fair chunk of more cash is required when including the TB and other bits and pieces that are required to install it, but, it is another option that is available to me if FAB9 one does fall down (but I really, really.....really, want the FAB9 one though) TL;DR. You want what you want
