Ok when i take my car out, It's usually boosting at 1 bar. But after lets say some hurting or long drives the boost will go down to 0.6.
Is this normal for skylines or is there something wrong. Keep in mind, I also have a minor oil seepage at the base of one of my turbos.
What yas rekon?
https://www.sau.com.au/forums/topic/146703-is-this-normal/
Heat! Your gate will loose tension with heat and gets worse with age.
Good quality EBC's are the way.
When I run cars with bleed valves or basic EBCs (many are just electric bleeds pulsing faster or slower to control boost but without and MAP sensor to chase a set pressure)on the Dyno boost drops each run as heat builds up.
https://www.sau.com.au/forums/topic/146703-is-this-normal/#findComment-2739207
