Hi guys
I bought a set of advan sa3r second hand 17"
My old nuts were too fat to fit inside the new wheels so i bought a heap of new ones.
The ones i bought seem to fit perfectly, but i have just taken the wheels off to spray them black and the front right wheel had 2 nuts that were so tight, even after using wd40 and a bit of oil to lube them up we could bearly remove them by jacking it back and forth until it finally came off very reluctantly. It wasn't like they were tight for a small part of the thread but from start until finish.
2 of the studs are partly stripped of their threads and need replacing as well as the 2 nuts.
I'm wondering how this could have happened so i can avoid it in future. im not a newbie to wheels and know not to overtighten or cross threads and what not else.
Btw, what are the stud sizes because i need to buy some more (and hopefully from a wrecker).
https://www.sau.com.au/forums/topic/146704-new-wheels-stripped-threads/
the two studs/nuts have been cross threaded.
shit happens.
this might have been caused by you putting them on wrong, or the threads on the studs/nuts not matching, or even being way over tightened.
just be careful next time.
when removing a wheel, i jack it up a tiny bit then crack/loosen the bolts while its on the ground (always doing opposites), then jack it up then undo it all the way.
when putting it back on, (again doing opposites) i tighten the bolts slightly to around 30% torque while the wheel is in the air, then drop the car and do them up all the way.
Hi guys
are you sure you used the correct pitch nuts? You said you used new nuts , were they all the same ? Nissans use 12x1.25 mm pitch, same as Subaru, others use 12x1.5 mm pitch.
You can buy the studs new from Nissan
i hand screw them in 90% of the way and only tighten the last bit by hand and i only tighten them enough to hold and check them the next day so its very unlikely i've overtightened them or crossthreaded them.
I do them in opposites from each other but i crack them on the floor then jack right up to unscrew and losen, that could do this?
The nuts are 12x1.25
cheers
cheers
Its very hard to strip them by overtighting them you brake the studs first.
Thats the way you should undo them, do them up. Maybe you had 2 different studs on? someone changed them to 12x1.5 mm before ?
Ye, unless you cross threaded em, possible wrong studs were in there?
Other than that... being a bit over zealous on the tightening wont cause it as above.
Sounds odd if your 100% you put em on correct and they came off good also
  • 3 weeks later...
Hi,
Had a similar problem on my much modified RX2. I had installed longer studs with a different bolt PCD. The long and the short is that the taper where the nuts seated in the rim was different to the taper on the nuts. Therefore when tightening the nuts the tapered end was forced narrower causing that part of the nut to bind on the stud...check the tapers and compatability of the two tapers.
Regards,
Jeremy
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
