r32 40mm widebody vented fiberglass gaurds need a bit of fiberglass work pm me for details $120
r32 m spec rear pods now in white 2 pack high fill primer also have side skirts
r32 stock rear bar $80
rb20det stock injectors 2 sets $50 each set
rb20det stock afm $65
rb20det stock turbo and dump pipe to cat turbo in ver good condition $170
work twings 17x8 front and 17x9 rears brand new tyres on rear and fronts are still legal chrome lip and silver centers (Centers have minor gutter rash)have origional work caps and all tags on rims will sell how they are for $950 or with black centers and the chrome lips and gutter rash repaired for $1000!
rb20det heads $90 each in vgc silver tops complete with rockercovers and cams
stock rb20det air box set up with brand new filter!
r32 g sensor in perfect condition
r32 gts-4 wing $40
rb20det turbo manifolds 2x $40 each
rb20det bottom half intake manifold $40
rb20det throttle body $50
gts-4 4wd sump diff has been pulled apart but all parts are there $150
gfb boost controler $35
Edited by OGR88 R32
yeah i guess its easyer to put it up here then pm everyone about it :( ok only problems 1 they need a good sand before paint and the 2nd is the one mount neer the door has broke off on both easy enough to fix but ive never used it anyways this is how they looked on my car
  • 5 months later...
  • 2 years later...
    • Can you at least move to a location without so many ladders, black cats and mirrors precariously propped up ready to be knocked down? Or buy yourself a 1 ton bulker bag of salt to drag around with you. Just, you know, sling it over your shoulder?
    • Meh, what's the worst that can happen? If is is supposed to have a washer, and: the spring retainer seals reasonably well on the surface, maybe just allowing a little bleed of oil out, and the spring does not coil bind when compressed that little extra bit, then the end result will be slightly higher relief pressure setpoint, and no other noticeable effects.
    • Weirdly I see a flat washer on aftermarket pumps but as you said it doesn't seem like new OEM pumps have it. EPC doesn't break out the regulator as a separate component either. I'm guessing if the pump came that way it's safe to use as-is.
    • I'm always a glass half full kinda guy. This will be a great project and the finished product will be awesome.
    • A local that insisted he learned from the best in Australia for RB builds managed to machine a head past the point of saving according to another shop and it dropped a valve too. Ghosted the customer and as far as I know nothing really happened to him. A coworker also recently told a story about owning a Porsche in Germany and running into issues with a dealer tech leaving scratches, oil stains, and missing parts all over his car. I'm not a master tech by any means but at this point I've seen enough expensive mistakes that I'd rather make them myself.
