Its a 1993 R33 Skyline Sedan, Garage Impul Special Edition -
number 67 of 100 made (little plate under the bonnet)
Engine/Driveline Mods:
RB25DET with HKS 2835 Pro Spec S, internal gate with HKS adjustable acutator.
Apexi Power FC with Boost Controller kit
Apexi Air Filter pod
Splitfire Coilpacks
Nismo 550cc injectors
Z32 Air flow meter
R33 GTR Fuel Pump
R33 GTR Front Mount intercooler
5 speed manual conversion with NPC Ceramic clutch and Nismo Style Heavy presure plate with Redline Oil in the Gearbox and Diff.
3 inch exhaust from turbo back, with high flow 3inch cat with Impul Stainless Exhaust
Nismo Shortshifter
Exterior
Impul R33r Body kit - each part has Garage Impul Logo on it
Interior
Apexi PFC hand Controller.
Impul Momo Steering wheal
Impul Recaro Seats
Apexi Boost Guage
Suspension/Brakes/Wheels
Impul RS 17 inch Wheels with Falken ZE512 (235,45,17 front, 255,40,17 rear)
Impul Shocks
Impul Springs - Lowered.
Impul Sway bars
Impul Strut strut bars
DBA 4000 rotors with Ultimate Pads
Servicing/Performance:
Tuned at Mercury Motorsport
230.9rwkw @ 1.05 bar - could get more, if you wanted to play around with the actuator
currently has 124 000 kms - Serviced every 5000kms with Mobil 1 - timing belt and water pump and other belts all replaced with nissan genuine parts. No Leaks, funny noises, runs perfectly and never missed a beat.
A fast car that handles amazingly well, very direct and firm and something you can carry the family around in. If your looking for something different, this is it.
Photos and carsales add here:
http://www.carsales.com.au/pls/carsales/&a...p;category_id=3
I have also attached a link to the list of cars they have produced.
http://www.impul.co.jp/products/complete-index.htm
PRICE DROP $17900 ono, trades or swaps considered.
pm me or email me at [email protected] or
call me on 0412 750 418
thanks
Matty
https://www.sau.com.au/forums/topic/146708-r33r-impul-skyline/
would like to know more since im in the market for an r33. since the carsales link doesnt work, can u email me the pics and your location ?
gervase AT allegro DOT com DOT au
    • 65601-05U00 is the hood latch. 62550-08U31 is the support that holds it to the radiator core support. They are all super discontinued so I don't really have any great leads on how to source this stuff.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
