Of the 3 i bought for installing on my car this was clearly the best quality and the only onw i considered installing on my car.
Selling because i now like the idea of no rear spoiler...so rather then it sit around may as well sell it.
Just Jap ask $195 plus delivery. Still in all original packaging. Asking $175.
Located in Melb, willignto discuss delivery arrangements
https://www.sau.com.au/forums/topic/146712-r32-n1-boot-lid-spoiler/
  • 3 weeks later...
hope they are still around when my engine rebuild is finished. keen for one. how are they attached, bolts or glue
i have a carbon one on mine i just stuck it on with sicaflex.looks good.
  • 4 weeks later...
  • 4 weeks later...
  • 1 month later...
It is not hollow. Im guessing it has a urathane centre as it is not hollow and has threaded nuts set into the underside to assist with securing it to the boot (in case your like me and want more then just double sided tape)
This is what it looks like when used in conjunction with the std rear spoiler. They were homologated for the R32 when they were in Grp A so im guessing it slows the velocity of air under the wing giving you a little more downforce .
It's exactly what im after.
There will be no difference from the 2 dr and 4dr as they have the same dimensions I hope.
I will get back to you asap ok ROY.
I am all cashed out at the moment.
If sold before hand thats life
  • 1 year later...
  • 1 month later...
if its still for sale i'll take!...which one is it? carbon or primered one? cause i kinda want the carbon one
forgot to ask where in melb are you from...either way i'll take it which ever one it is! lol
Edited by jakez88
  • 3 weeks later...
    • 1. Factory knock sensors for now, honestly the RB26 OEM knock sensors seem ok as they're flat response instead of resonant type but they appear to be internally grounded to the block. If I do replace the sensor it would just be to get ones that are not internally grounded so a differential input can be used to reject common mode noise. Definitely plan on fixing this as a part of the tuning process. 2. Never deliberately induced knock, though I guess I could try that experiment if I really wanted to. 3. All of this is basically on a stock engine + ECU, only modification is HKS GTIII-SS turbos and a Nismo plenum. Currently I run it with the wastegate solenoid unplugged so it won't try to raise boost past wastegate pressure.
    • After being peer-pressured into paying $100 for the MW remakes, got BO6 on XBox Game Pass. I think that's worth it.
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
