N I B. quick question.
Most times it seems that the switch is connected to the fuse inside the cab near the drivers knee.
When I chased mine down, I wired into the fuse in the engine bay box. This, according to the schematics I have, just removes power to the ETS motor, not the ABS motor as well.
Is there a bad point to doing it this way, or is it just easier in cab?
(other than the link being higher current run)
The way you've done it is the better way because (as you pointed out) the engine bay fuse disables 4WD only and leaves ABS functioning. The cabin fuse kills both. The reason most people use the in cabin fuse is it's easier as less wiring. Providing you used thick enough wire there will be no problem with the higher current.
does it pulse? I can't remember for sure, but I'm pretty sure I've done a standing burnout before with the engine fuse out. could be wrong those, i may have used the cabin one those times.
  • 4 years later...
Ive got one of those torque splitter and RWD/4WD switches in one... though everytime i flick the RWD swith while the car is running it blows the fuse, though if the cars off and i flick it and then start the car it works fine
Any ideas on why and how to fix it?
so is it true you cant do a standstill burnout with ABS functioning?
I can do a standstill with ABS enabled but if i ease off the brake to start moving it doesn't like it.. pedal gets really hard and won't let you slow the car up again until the rears stop spinning.
I have a switch and a method for 2WD (it's pretty much 33gtr setup) and it doesn't disable ABS, if I wanted to hook a switch for this I just need to tap into the ABS fuse yes?
Are you doing it while dead still? You can't change it while the car is in motion
Haha, funny dude..
I have been in a Gtr that would switch while driving, is it just bad to do it when cruising or has he done something more? It looked like more than just a switch wired in.
Also, my front/ rear torque gauge thing(to the left side of cluster) doesn't respond and sometimes my tyres screech around corners, does this mean I'm only running 2wd?
Cheers guys.
Ok, silly me. all this talk about fuse breakers made me do the obvious.. CHECK MY FUSES!! Turns out my(under the hood) 4wd fuse was put in the empty spot nxt to where it should have been. It look intact so I went to put it in place(with ignition off obviously) and I could hear a buzzing from the rear of the car so I panicked and pulled it. Is this normal? Can any of u gurus work out why he would have moved the fuse out of line? Cheers again.
Jesse.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
