Lowered it (sits as high as a navara...) and removed the door handles... Notched the wheels up a couple of inches.
My first attempt at photoshop. Pretty basic, but i have no real idea what im doing. Plus, i actually busted it out in mspaint cos i dont have a photoeditor... good fun.
Subtle, but what do you think, guys?
Edit - reposted photo... mustve gon on before cos it had been downloaded heaps of times according to 'my controls'... hmmmm... SKA...?
Edited by qikstagea
https://www.sau.com.au/forums/topic/146749-photoshopped-my-stagea/
