Murry33 Posted December 10, 2006 Share Posted December 10, 2006 My r33 gtst has been running a bit rough lately, seems to run really rich and i can smell fuel......it's just been sluggish really. problems so far are: - Fuel pump is loud, and car has trouble starting in the mornings (i'm assuming i'll have to change that this wk, how much are they usually?) - I don't seem to be getting much boost, even if it's a cold night and i give it a fair bit! (was boosting great a week ago though..) - & i'm thinking the bov is leaking perhaps as when i adjust it, it tends to stall at random times!. (could be the fuel pump) OK It's just have a full service, people have been recommending a dyno tune?. Since i have the stock ecu will the dyno tune fix the car from running rich and overall improve it? What have your experiences been with dynos using stock ecu?, any decent power increases? oh and before somel start saying "do a search" i have, oh yes really it's true lol. but i couldn't find the exact answer i was looking for, so i'm asking you's k thnx cheers! Link to comment https://www.sau.com.au/forums/topic/146750-r33-running-a-bit-rough/ Share on other sites More sharing options...
mickr33 Posted December 10, 2006 Share Posted December 10, 2006 You have PM......... Link to comment https://www.sau.com.au/forums/topic/146750-r33-running-a-bit-rough/#findComment-2739605 Share on other sites More sharing options...
chinkeboi Posted December 10, 2006 Share Posted December 10, 2006 if its a stock intake fuel pump then it should be relatively quiet. It getting louder usually means its on its way out. That or you have a aftermarket pump. Hard to start in the morning could be your injectors are clogged/dirty/broken. That or sparkplugs.. most likely the injectors though. lack of boost could again be fuel pump.. or afm or many other things.. my moneys on ur fuel pump. don't just tell your mechanic to change the pump.. ask him to test the fuel pressure first.. as it may not be it Link to comment https://www.sau.com.au/forums/topic/146750-r33-running-a-bit-rough/#findComment-2739684 Share on other sites More sharing options...
mad082 Posted December 11, 2006 Share Posted December 11, 2006 dyno tune won't change a thing as the stock can't be altered without a remap. the problem could be that you either have a bad boost leak (check intercooler piping), the afm is stuffed, or the turbo is stuffed. Link to comment https://www.sau.com.au/forums/topic/146750-r33-running-a-bit-rough/#findComment-2740351 Share on other sites More sharing options...
Murry33 Posted December 11, 2006 Author Share Posted December 11, 2006 Thanks for the replies! i'll check the fuel pump, the car has fmic,bov,cat back exhaust system. Might change the bov to a stock one? would that be okay running say 10psi boost? Link to comment https://www.sau.com.au/forums/topic/146750-r33-running-a-bit-rough/#findComment-2740646 Share on other sites More sharing options...
mad082 Posted December 11, 2006 Share Posted December 11, 2006 i have a stock bov running 14psi. Link to comment https://www.sau.com.au/forums/topic/146750-r33-running-a-bit-rough/#findComment-2740854 Share on other sites More sharing options...
Murry33 Posted December 11, 2006 Author Share Posted December 11, 2006 cheers mate!, i've got a plump back GFB bov, that can be adjusted to be silent........would that make it legal you think? Link to comment https://www.sau.com.au/forums/topic/146750-r33-running-a-bit-rough/#findComment-2741263 Share on other sites More sharing options...
mad082 Posted December 11, 2006 Share Posted December 11, 2006 should be legal if it is plumback. Link to comment https://www.sau.com.au/forums/topic/146750-r33-running-a-bit-rough/#findComment-2741460 Share on other sites More sharing options...
Murry33 Posted December 11, 2006 Author Share Posted December 11, 2006 (edited) turns out the lack of boost was a huge air leak in one of the rubber hoses..& ok well i talked to the mechanic, he'll check out the fuel pump tommorow. I was going to get steel piping done to replace some of the rubber/plastic piping from the turbo to air filter already there but he thought it wouldn't make much difference performance wise. So i will probably be getting a dump pipe installed instead and boost switch to change between stock boost & 12psi boost ?. let me know what you think! Edited December 11, 2006 by NeesaanGTS Link to comment https://www.sau.com.au/forums/topic/146750-r33-running-a-bit-rough/#findComment-2741638 Share on other sites More sharing options...
ky_r33 Posted December 11, 2006 Share Posted December 11, 2006 turns out the lack of boost was a huge air leak in one of the rubber hoses..&ok well i talked to the mechanic, he'll check out the fuel pump tommorow. I was going to get steel piping done to replace some of the rubber/plastic piping from the turbo to air filter already there but he thought it wouldn't make much difference performance wise. So i will probably be getting a dump pipe installed instead and boost switch to change between stock boost & 12psi boost ?. let me know what you think! If your car is running rich, it could be the oxy sensor. Mine was chewing thro the fuel, then i had it dynoed and had the oxy sensor replaced and it run heaps better. My car is stock and has 160kw @ the wheels Link to comment https://www.sau.com.au/forums/topic/146750-r33-running-a-bit-rough/#findComment-2742077 Share on other sites More sharing options...
Murry33 Posted December 11, 2006 Author Share Posted December 11, 2006 thanks! i'll ask the mechanic to check that too, mine is chewing a fair bit of petrol actually..........ahh skylines when does it end ? lol Does anyone know what sort of power gains you get from getting a new turbo dump pipe?? Link to comment https://www.sau.com.au/forums/topic/146750-r33-running-a-bit-rough/#findComment-2742239 Share on other sites More sharing options...
Murry33 Posted December 12, 2006 Author Share Posted December 12, 2006 Okay well i got quoted: $220 for oxy sensor(broken), $750-dump pipe,gaskets, 3inch cat converter. Then a few hundred extra for dyno tune before/after. do these prices seem right? Link to comment https://www.sau.com.au/forums/topic/146750-r33-running-a-bit-rough/#findComment-2743379 Share on other sites More sharing options...
RBwhatever Posted December 12, 2006 Share Posted December 12, 2006 (edited) Okay well i got quoted: $220 for oxy sensor(broken), $750-dump pipe,gaskets, 3inch cat converter. Then a few hundred extra for dyno tune before/after. do these prices seem right? O2 Sensor - $80 from eBay, you can probably get it even cheaper elsewhere. Ebay O2 Sensor for R33 3 inch Xforce Hi Flow Cat - $199 from Just Jap. 3 inch Xforce Bell Mouth Dump/Front Pipe (1 Piece) from Just Jap Stainless - $330 Mild Steel - $195 http://justjap.com/parts_nexhaust.htm or if you want a split dump, check out the group buy for batmbl split dumps and front pipes and hi flow cats. http://www.skylinesaustralia.com/forums/in...howtopic=136607 BATMBL Stainless Split dump and Front pipe and 3 inch Catco cat - $540 Edited December 12, 2006 by KeyMakeR33 Link to comment https://www.sau.com.au/forums/topic/146750-r33-running-a-bit-rough/#findComment-2743537 Share on other sites More sharing options...
Murry33 Posted December 12, 2006 Author Share Posted December 12, 2006 Thanks! yeah those prices are with labour included etc that i quoted, so i suppose it aint a bad price. Will the dump pipe give me much performance increase over what it is now(stock)? Link to comment https://www.sau.com.au/forums/topic/146750-r33-running-a-bit-rough/#findComment-2743614 Share on other sites More sharing options...
RBwhatever Posted December 12, 2006 Share Posted December 12, 2006 (edited) Huge difference. Just bump the boost up to 10 or so and it'll be a different car. If you and a mate are handy with a spanner, then you can do all that bolt on stuff yourself. Save yourself hundreds of dollars in labour costs. Edited December 12, 2006 by KeyMakeR33 Link to comment https://www.sau.com.au/forums/topic/146750-r33-running-a-bit-rough/#findComment-2743642 Share on other sites More sharing options...
Murry33 Posted December 12, 2006 Author Share Posted December 12, 2006 Cheers! I hope it's a huge difference. Altogether it's costing me about $1400, with new o2 sensor, 3inch cat, dump pipe, gaskets etc. Also includes before/after dyno tune+labour. I just got the car and it's costing me heaps haha.... Whats the best way to increase the boost, they wanted to install at switch to change from stock/12psi boost.....for like $500 though lol? i thought there must be a cheaper option..boost controller? but thought they are illegal..duno Link to comment https://www.sau.com.au/forums/topic/146750-r33-running-a-bit-rough/#findComment-2743704 Share on other sites More sharing options...
RBwhatever Posted December 12, 2006 Share Posted December 12, 2006 Cheers! I hope it's a huge difference. Altogether it's costing me about $1400, with new o2 sensor, 3inch cat, dump pipe, gaskets etc. Also includes before/after dyno tune+labour. I just got the car and it's costing me heaps haha....Whats the best way to increase the boost, they wanted to install at switch to change from stock/12psi boost.....for like $500 though lol? i thought there must be a cheaper option..boost controller? but thought they are illegal..duno Turbotech BC Got a spare 30 bucks? one of these is more than adequate. Takes 5mins to fit. Link to comment https://www.sau.com.au/forums/topic/146750-r33-running-a-bit-rough/#findComment-2743750 Share on other sites More sharing options...
Murry33 Posted December 12, 2006 Author Share Posted December 12, 2006 Aweasome!, and they wanted $500 lol...ttshh. I'll let ya's know how it goes Link to comment https://www.sau.com.au/forums/topic/146750-r33-running-a-bit-rough/#findComment-2743754 Share on other sites More sharing options...
Murry33 Posted December 13, 2006 Author Share Posted December 13, 2006 (edited) OK talked to the mechanic, i thought because it's running rich the new o2 sensor should make it run normal again?. He thinks that even if i replace the o2(which is completely stuffed) it will still run rich as long as it has the standard ecu? Also hasn't rectified the starting cold in the morning problem, the fuel pump tested out fine...duno? Edited December 13, 2006 by NeesaanGTS Link to comment https://www.sau.com.au/forums/topic/146750-r33-running-a-bit-rough/#findComment-2747164 Share on other sites More sharing options...
Sambo33gtst Posted December 13, 2006 Share Posted December 13, 2006 (edited) Bro, be very very careful with your boost levels once you have your dump pipe put on. If you fook around with your boost after ur dump pipe is put on, your gonna put ur turbo at risk. A good mod to do when u do a dump pipe is an electronic boost controller. Your not your gonna get boost spikes if this is done, and your turbo will love you forever. But yes, you will notice a decent difference. Turbo will spool up much quicker. Edited December 13, 2006 by Sambo33gtst Link to comment https://www.sau.com.au/forums/topic/146750-r33-running-a-bit-rough/#findComment-2747196 Share on other sites More sharing options...
