  • Replies 71
"Everybody else" still seems to be Birnie and myself.
I haven't changed any of the corrections, and it's still running just fine.
In the absence of information from any of the experts regarding what latency or lag time actually is, it seems that it is not a critical figure. The correction for flow rates, is.
hah, yeah that's right Dale ! :)
.....although Ben has joined the club too
Just check my settings as i forgot all about it since being tuned by The Hitman,
He has em setup as 72.0 % and +0.10 Latency?? Go figure.
As far as the 72% goes, i guess his full tune would be applied to that setting so i wouldn't advise using that as a temporary figure to get to the tuners......stick with the 82.5..it's a proven working setting, then let the tuner do whatever they want.
PS...The Hitman RULZ !
Any upadate on the latency for the S15 injectors? Is -0.06 the setting everyone else is still using?
Getting my tune tomorrow.
444cc and 0.5 as i posted only a page ago :)
I used the below and put in +0.06 as calculated. Also used the 82.5%. Tune done at MRC Castle Hill. Got a nice 247.4rwkw (18psi peak trailing back to 16psi).
Tough to test in the wet though. Spins from 4000up.
Good tune at a reasonable price.
Thanks Birnie and Dale.
How do I configure larger injectors?
Configuring larger injectors into the PowerFC is quiet simple and takes only a few moments. You need to know the following information before you can continue
Current injector size
Current injector latency
New injector Size
New injector Lag time
Injector Size and Latency (standard units)
Unit Size Latency
RB26 444cc/min 0.772msec
RB25 370cc/min 0.528msec
SR20 (Jap Spec Manual) 448cc/min 0.584msec
Nismo 480cc 480cc/min 1.100msec
Rx7 550cc 550cc/min 0.730msec
Aftermarket New Units 600cc/min 0.810msec
To work out new INJECTOR correction and latency;
Old SIZE / New Size = Correction
New Latency - Old Latency = Latency Correction
John plans to install 600cc injectors into his RB26 VL Turbo. The following figure's are used;
444 / 600 = 0.74 * 100 = 74.0%
0.81 - 0.77 = +0.04 msec
So he would enter 74% for correction and 0.04 as new latency
Once you have switched to larger injectors you should still check your AFR's with a wideband to ensure they are safe and acceptable.
For a list of common OEM injectors and their settings try here;
Injector Chart - Side Feed OEM
Injector Chart - Top Feed OEM
i forgot to ask. When I plug the Hand controller in again (and when it's dry :P) Ill do a few 2nd gear to redline pulls and check the peak.
He didn't say that they were close to maxing out but I reckon they wouldnt have much left.
Edited by benl1981
best to check duty in higher gears. 2nd doesnt have enough load.
  • 8 months later...
I thought I'd crunch some numbers about RB25DET injectors and larger direct fit replacements to put y'all in the picture .
Std - 370cc , S15 T manual - 450cc , Nizmo 555 and 740cc .
If you divide the std 370 by 450 555 and 740 you get 0.82 , 0.66 , 0.50 .
So I guess this means the S15 Terracotta coloured ones are ~ 18% larger , 555's are 33% larger , 740's are 50% larger .
I ended up buying new Nismo 555's from a member here which I reckon would be fine for my power requirements using PULP , trouble is if you ever decide to use high ethanol fuel blends such as E85 (if it becomes readily available) you need injectors approx 33% larger than you would with PULP to maintain chemically correct AFR's for E85 .
Where that leaves me is line ball (555's vs 370's and PULP vs E85) so in hindsight if I knew then what I know now I would have bought Nismo 740cc injectors .
Nismoid uses/used 740cc Nismo's I believe in an RB25 and had no issues at idle or light loads - on PULP ?
Cheers A .
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
