Official Sauwa Xmas Cruise 2006
dan_the_man
 Share
  • Replies 150
With a bit of luck I could be there running my new engine in, either that or in the Z :P
My work function is that night too, but priority dicates that cruising comes before boozing :)
Paulie - i may not be there as i said to mel i would catch up with her before xmas and so we chose friday night.
Actually this thread never mentions whether non-skylines may attend...had a friend ask if his silvia could come along.
I especially like the part on the first page where it says:
"Only for SAUWA member or can general forumers attend too??"
"i would assume that it is an open cruise as its not in the wa members section"
"open to non members"
yes you and your friend may come along to our cruise
Niz. No worries, looks like my car should be ready anyway :O
CHOP CHOP PAULLY BOY
Now Im going to get excuses like "Im running my engine in" and "It is not fully tuned yet" lol hehehehehe
Look forward to seeing the car out on friday, then everyone can see you colour scheme for you engine bay, mate Im jealous of that one. :rofl:
Judge :ninja:
hey dan can i sms u for locations when i finish work? i don't think ill make the city west meet point cause i only finish work at 10 :ninja: and j tuned doesn't think he'll make it :) mmm and i really want to go
Cheers
Chi
yeh man, was gunna PM u, sorry bout that :)
 Share
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
