one thing you can try is take the wastegate arm off the flapper and wire open the wastegate you should make no boost if it does create boost then the wastegate hole is to small. if so whip the turbo off and port out the wastegate hole either yourself if your feel confident to do so, or get some one to do it for for you.
also take off the lever/arm off the flapper with the dump pipe on and operate it by hand see if it catches anywhere. BATMBL dump pipes in my opinion are the bomb but are designed for a stock turbo your hks one although is made to be the same may have a suttle difference in the flapper i dare say it may actually be larger so check what i said above and make sure it doesnt foul on the dump simple fix for that is to get out the die grinder.
if you have alook at my old posts ive gone through all this before so you may find some help in there
does anyone have any instructions or pics of porting out the standard wastegate?
ive got the same problem, and dont wanna have to fork out for an external gate.
when you port out the gate, do you need to replace the flapper valve as well? or is it big enough that it can cover a slightly larger hole just as well?
you will first need to remove the turbo, depending on how much overlap the flapper has over the wastegate hole will determine if you will need a new flapper.
ideally you want 2mm of overlap after you port it, if less than 2mm the flapper may not full seal and you will need to replace it with a larger flapper. (if it doesn't seal you will lose response)
you need to remove the exhaust housing off the turbo so you don't get crap left in the housing, remember to smooth the surface on the inside of the exhaust hosuing too. personally I am going to remove my turbo take mine to a turbo shop and pay them to do it for me to solve my boost creep issues
Before possible wasting your time and money on uneccessary solutions.
Firstly, inspect the hose connecting your wastegate actuator
to your intercooler return pipe. It may have a split or hair-line crack,
which are hard to spot. At the cost of $5 I would replace it.
A leak in this hose will bleed off air and cause
your turbo to reach high boost levels, causing its destruction.
Secondly, before removing your dump to inspect the wastegate
valve supposedly hitting your dump-pipe.
Use a needle-nose air squirter hooked up to an air compressor,
remove the hose off the actuator and stick the needle into the
actuator's nipple and squirt some air into it.
Your actuator should open-up quite freely, it can easily be heard.
You should be able to hear wether or not its hitting the dump-pipe.
If it does not hit the dump, but opens up slowly with lots of air
pressure, you might have a sticky actuator.
In this case, your better off purchasing a 12psi adjustable actuator.
From recent experiences, it would be wise not to get a universal
actuator and bend and heat the rod to suit your application.
Purchase a U-shaped rod, if required from the turbo place.
Hope this solves your problems. :(
Cheers,
Bill
Edited by Nabil
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
