Hi,
Car:r33 RB25det
Type: Manual 93.
I have bleed the master and slave cylinder but i can't get the clutch pedal to return to the top of the stroke. It seems to sit in the depressed position. Does anyone know what the problem is and how i rectify this?
After you bleed it pull the pedal back up by hand then try it, it should be ok then.
Don't stress just yet.
I just changed my Slave Cylinder an hour ago. It took 5 mins to change and over an hour to bleed the stupid thing. I'm still not happy with it, but it's working, so it can wait till another day.
Feel free to correct me if I am wrong, but there are 3 bleed points. The Master Cylinder, the loop, and the slave cylinder. You need to work your way down, I bled them all atleast 5 times before I even got pedal feel back. Crazy.
ok. if theres air in it to the point where theres no pedal. it will spring down. anyway....
first up. its a pain in the ass.but.
you need two people to do it. open the master clyinder bleed nipple first. push down , close the niple up. pull up. open it push down, close it , pull up..
do this till no more air come out the nipple. should take about 3 strokes.
next do the one on the big loop thing. this one takes a few more. say do that one about 5 times.
then do the slave. say another 5 strokes
each time the pedal is depressed it will need to be pulled up by hand. do it slowly coz if it flings up it will draw air in thru the master.(seals only work in one direction.)
if its being a prick back of the push rod on the master cyl. (12mm nut and wind the rod in a little) to give abit more slack.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
