Not as such, but i've heard that its pretty tricky to do without breaking it.
I'm not sure how accurate this is though, it might have just been the panelbeater spinning sh*t so he could charge more
Yes.
But we used a window remover thing, kinda like a cross between an electric knife and spatula.....cuts through the black gooey stuff and out she comes.
Thanks for the reply Duncan, how did you get the surround of the window off?
hmm don't really remember must have been fairly straightforward. Inside trim is held in with clips, so you yank them out breaking them all and then look around local car part shops hoping to find new ones to match so you can put it back in.
I assume there is a proper way to do it though :ninja:
yes it is. the rubber seal and the glass is one piece. my advice is dont remove them unless you have no other choice. When I resprayed my car I insisted they remove them to ensure good finish, and no build up. BUT they told me I was being pedantic and that if masked properly, and painted properly it wouldn't be a problem. I wish I listened. mine came out, and went back in but the seals dont like quite the same as they did before :ninja:
The quarter glass and seal is one piece, but between the glass and the metal of the car body is a sikaflex bead seal.
Panelbeater broke my right side qtr as well, it had to come out to get at the cancer. The replacement looks good, whilst the original on the left has a banged up outer seal.
  • 1 year later...
There's also a 10mm nut on the inside rear. Hard to believe but true. The stud for the nut is bonded to the glass. I removed mine when we painted the car with the tried and proven piano wire method. Careful not to damage it at all, as the seals don't come away from the glass - one piece.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
