Hi, I have a 1985 r30 hatch with power windows that has registration due on wednesday, and failed it's inspection today due to not having the controls for the rear power windows in the rear. I'm around the Sydney area and need to buy or (if someone is very kind) borrow the rear passenger and driver power window control switch things. The wiring is all there, just need to plug it in then take it back to get pinkslipped and registered.
Like I said, I'm in Sydney in West Ryde. If someone can help me out with some spares, shoot me an email at [email protected] or reply here.
Cheers.
Edited by HunterDevourer
Cheers.
your best bet is to just try a few wreckers
can you use some switches from another car (R31 Ti? Mazda 626...)and retro-fit them to suit?
if the look stock enough it might work, im sure they dont know exactly what r30 power widow switches look like
It must be different in NSW, but when I tried to get my R30 rego transferred here in Vic, the driver's window didn't work, and it's the only one that MUST work. So I simply swapped the motor from the rear RH door into the front RH door, and Robert became my uncle.
It passed a blueslip without them last year, but failed the pinkslip this time because of them. Different mechanics. I had no idea it was a fail item, and most people i've talked to don't think it should be. I've bought some bits from jaycar but couldn't get them working (2 switches with off position in middle, power on up and down).
I might be able to retro fit some switches from other cars like the r31 etc....but I now can't drive anywhere to get them.
I checked out drivers side power window door control as well, but it's no help as it has a different number of wires anyway.
  • 4 weeks later...
I had the same problem and ended up using a C31 Laurel rear switch for a while that worked fine, I'm guessing anything of that era would be more or less interchangeable. They're not the same cosmetic design, but the wiring is identical.
Those R30 rear switches are a downright pain, the internals always fall apart and then you're stuck with the whole assembly in several pieces. Must be something to do with the way they're vertically mounted on the doorcards, people push on them too hard and over the years they just get more and more worn out until they finally break. In fact I'd probably say that the C31 switches (which were designed for horizontal mounting) are far more robust than the R30 ones.
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
