Hi, I have a 1985 r30 hatch with power windows that has registration due on wednesday, and failed it's inspection today due to not having the controls for the rear power windows in the rear. I'm around the Sydney area and need to buy or (if someone is very kind) borrow the rear passenger and driver power window control switch things. The wiring is all there, just need to plug it in then take it back to get pinkslipped and registered.
Like I said, I'm in Sydney in West Ryde. If someone can help me out with some spares, shoot me an email at [email protected] or reply here.
Cheers.
Edited by HunterDevourer
Cheers.
your best bet is to just try a few wreckers
can you use some switches from another car (R31 Ti? Mazda 626...)and retro-fit them to suit?
if the look stock enough it might work, im sure they dont know exactly what r30 power widow switches look like
It must be different in NSW, but when I tried to get my R30 rego transferred here in Vic, the driver's window didn't work, and it's the only one that MUST work. So I simply swapped the motor from the rear RH door into the front RH door, and Robert became my uncle.
It passed a blueslip without them last year, but failed the pinkslip this time because of them. Different mechanics. I had no idea it was a fail item, and most people i've talked to don't think it should be. I've bought some bits from jaycar but couldn't get them working (2 switches with off position in middle, power on up and down).
I might be able to retro fit some switches from other cars like the r31 etc....but I now can't drive anywhere to get them.
I checked out drivers side power window door control as well, but it's no help as it has a different number of wires anyway.
  • 4 weeks later...
I had the same problem and ended up using a C31 Laurel rear switch for a while that worked fine, I'm guessing anything of that era would be more or less interchangeable. They're not the same cosmetic design, but the wiring is identical.
Those R30 rear switches are a downright pain, the internals always fall apart and then you're stuck with the whole assembly in several pieces. Must be something to do with the way they're vertically mounted on the doorcards, people push on them too hard and over the years they just get more and more worn out until they finally break. In fact I'd probably say that the C31 switches (which were designed for horizontal mounting) are far more robust than the R30 ones.
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
