hiya all was wondering if anyone else on here has had problems with their car developing a tendency to drift over the road surface? mine has recently developed this problem aand i suspect (after 4 wheel alignments) that the rear steering rack maybe causing it? before i got the rear camber corrected and the front caster done i t would always pull to the left a little but now it can go either way at random times, its not a drastic pull but it is enough that if you let your hand off the wheel that the next bump/ridge in the road surface will cause the car to drift across over the course of around 50-60 metres or so.
any ideas guys as it is pissing me and the wheel alignment guys off to no end, (prolly seeing as he cant charge me until he gets it right) gotta love service garuntees hahahahahaha
cheers oxford
https://www.sau.com.au/forums/topic/146911-wandering-stagea/
What's your front caster setting? even caster is best for cornering,but on cambered roads,the car will follow the road camber noticeably if the caster is even. set the O/SF back half a degree and it'll track straighter when cruising around.
What other settings are you running out of interest?
Justin...
heya andy
yeah i have printed out the entire suspension thread around 80 a4 pages at work and the guys have based their settings on getting as close to the ones in the thread as possible but it still wanders
the alignment is being done at my local pedders workshop on a CORGHI brand alignment machine whether that would make any diffwerence or no i dunno. it is a new machine prolly less than 2 years old
SK offers caster kits in the Suspension Group Buy, and has settings for when you add those... Apparently you need to add a caster kit to add a sufficient amount of caster to get rid of the wandering...
Drop him a PM, and he may be able to help. Also, have a look in the Suspension Group Buy thread...
have already added a caster kit to try and bring the left hand side further to square and it hasn helped any, althouhg it was only one offset bush in the left (passenger) side so i may hafta get another offset and push the drivers side back or something??
Mine sufferes a similar thing - follows every single hole and dip and camber in the road. My old falcon you can pretty much let go of the wheels at 100kph and be good for at least 2-300m, but the stagea.... no.... Am going to try SKs camber and caster kits.
have pretty much put the same stuff as in the kits he has already and hasn really made that much of a difference unfortunately. only one that is different is the rear i have adjustable camber arms but they will be goin soon as i get the offset bushes for the rear arms
well shit... beats me then lol
If i figure out what it is, ill let you know! PS u do the same!
Ummm, it doesnt seem completely normal to me.
I dont believe my Stagea (S1 , Jan 97) suffers from what you desribe.
Doesnt wander, doesnt track offcentre, and I still havent had a wheel alignment done to it yet.
Mods: Bilstein shocks, standard springs, 360mm ride height all round (centre of wheel to arch), 17inch R34 GTT wheels with 235/45 tyres, and Whiteline 'pineapples'. Whiteline front caster kit not yet fitted.
Im honestly very happy with the handling, I mean its no Lambo but for what the Stagea is its great - as we all well know. Albeit Im a careful driver, I havent come across your described problem in my car (have with a Pulsar N15 hatch tho!!! long story....)
It'll be wear & tear on a particlar item I guess. Has you car got signs of accident damage? Have you replaced all the undercarrage bushes, etc? What condition are your tyres in? Is your current suspension old/new, installed properly? etc etc...... power steeing fluid/lines, steering rack, plenty of things to go thru.
Id had enough of the mucking around with our kittedout N15 hatch, that was a nightmare in regards to wandering characteristics and we never got it properly sorted in the end. Oh, and the 3 clutches in 20thou kms! :laugh: Was in Hot 4s tho on the backpage, so that was good for a laugh.
Best of luck with it, would be good to get different opinions from different workshops perhaps, time permitting. Maybe take out the hicas and put in the lock bar? Cant be of much help tho, sorry.
:rofl:
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
