a: Not sure yet, send me an e-mail and I'll add you to my mailing list.
b: FUEL PUMP, and a good quality boost control (Turbotech FTW)
ok cheers, yeh i forgot to mention i got a bosch 040 and that cheap pneumatic boost controller that u supply. so sounds like im set, ill throw u an email.
Edited by nisskid
You coming back to QLD anytime soon? i have a 34 in need of a remap ;)
Mercury Motorsports in Brisbanse have the capabilities, e-mail me for more info.
gb on dr_drift remaps!!! im seriosly considering selling the pfc i have (r33) to pay for the remap which should do the same job + allow for further mods at time of tune.
The 33's have a different ECU which is difficult to remap. We've had some excellent results using R32 ECU's in R33's with an aftermarket VCT controller to control the boost, including the 32 ECU, VCT controller, Remap AND Dyno time, it still works out cheaper than a PFC UNTUNED
  • 2 months later...
    • I hope one day I can do it like you. Your engine looks great.
    • If there's nothing else I can do I'll probably do something like that Someone on the internet said that ca20s and ca18 engine blocks are the same and that you can use a ca20 engine block and put ca18det parts to make a ca20det Do you think this is possible or will it damage the engine?
    • Yeah, I did some research and found out that some things are different.
    • Makes sense, thanks! Consider me very impressed. And I very much appreciate the effort in documentating all of it. You'd be surprised, or maybe not, how many people this reaches who search for things online. Anyways, I shall continue to read all of it, understand maybe a quarter, and hope that some of it sticks if I ever end up in a situation where it's relevant
    • 'Did' work on them is more accurate ~ on the R31 Skyline forum, you can spot me as 'Solder'... I've written quite a bit about the 4R01 boxes there, and I ended up reverse-engineering the older TCU type operations, so we could fudge a custom TCU to pull off other tricks...and like all things, when you do it a lot, see the failure patterns, have to find parts etc etc, your head ends up filled with whys and wherefores... there was a reason Nissan went with these in more than 60models over 16+ years... all in all, the JR401E based design is an interesting study, as Nissan changed things over the years in a never ending battle against them lunching on themselves <grin>...by the time the RE4R01A rev.C came out (often referred to as RE4R01B), they'd more or less perfected the design...
