Ok folks, A couple of item here for sale..........
ITEM 1
Velo Race Seat
Black
VERY GOOD condition
Fixed rail to suit R33, R32, A31, C33
Suit slimish build
180cm tall
Low seating
ASKING $350ono GET IN QUICK
ITEM 2
R33 GTR Wheels
17x9
+30 Offset
Set of 5.......... yes thats right a set of 5, you get one so the boot doesn't feel left out!!!!!
ASKING $1700ono
Reply here or send a PM and we can go from there
Cheers
Darren
https://www.sau.com.au/forums/topic/146946-r33-gtr-rims-and-velo-race-seat/
what kind of tread are on the tyres
willing to post to melbourne?
As per picture, looks like about 50%, Actually selling for my mate who IS on here named "Rhiga" he just doesn't hava a computer! I'm sure he will send to Melb at your cost obviously!
i only see 4 wheels in that pic...
i can offer $1200 delivered for all 5.
pm if you want.
Sorry fella awaiting someone to confirm they want 4 for $1200 in SA, and possible buyer for the 5th for $200 minus tyre! If anyone can beat this, then they can have!
Oh yeh and that pic is not the actual rims sorry people, they are on a cefiro ATM with is getting sold minus wheels!
Edited by Deluxe
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
    • So unsafe would you say now?   little bit of has come off, guess road salt is a nightmare for Japanese car. Mx5 here have a well known issue or rotting
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
