hi there
done a search, dug up some old threads - need some confirmation with some things!
i'm looking at some whiteline adjustable swaybars - from what i've seen S13 and GTR both fit front and rear? Would the GTR be thicker? if not i'll just get S13 adjustable front and rear.
what thickness is available (thickest possible)?
what are part codes for the whiteline bits?
thanks
-Matt
https://www.sau.com.au/forums/topic/146963-swaybars/
Thanks resin
what is the thickness of your S13 front and rears? i think i read you got the blade adjustable type?
what is the difference with the blade adjustable type? Blade adjustable thicker? and how thick?
i've emailed whiteline - and they werent very helpful - couldnt even recommend a s13 one.
spoken to gary also - but i need these quicker than that - and also will be organising through one of my sponsors, and i think gary only wanted to sell through himself as it is his design (which is perfectly OK).
thanks
-Matt
https://www.sau.com.au/forums/topic/146963-swaybars/#findComment-2743370
hi huddy
yea the s13 adjustable fit, this is what i have for my car.
Although there will be a cefiro one soon, made up from my stock ceffy front bar. im testing the new whiteline proto type on my car at the moment organised through sydneykid.
Wonder if they would fit a bigger sumped sr20 conversion - they're pretty common these days in Aus.
https://www.sau.com.au/forums/topic/146963-swaybars/#findComment-2743408
well the blade adjustable bars are 27mm at front and 20 at rear. 3 adjustment holes on bar at front (and two in the bracket) and 2 adjustment holes in the rear bar.
Interms of room in the front around the stock rb20 sump the ceffy and s13 bars are the same ...there about 10 to 15mm space. if thats anyhelp.
https://www.sau.com.au/forums/topic/146963-swaybars/#findComment-2743617
Front - Swaybar-h/duty Blade adjustable. 92-94 SR20 - BNF21Z - 27mm
Rear - Swaybar-h/duty Blade adjustable - BNR20Z - 20mm
Other Rear - Swaybar-X heavy duty Blade adjustable - BNR20XZ (not entirely sure) maybe 20 with additional adjustment hole maybe ...dunno
https://www.sau.com.au/forums/topic/146963-swaybars/#findComment-2743657
On the Group Buy there are 22mm and 24mm rear adjustable stabiliser bars.
Whiteline have indicated that due to lack of numbers, they won't be listing the Cefiro front bar.
So I will be making both front and rear bars available on a Group Buy early in the new year.
They will be part of a full kit same as Skylines R32/33/34
:laugh: cheers :)
https://www.sau.com.au/forums/topic/146963-swaybars/#findComment-2743793
go signatures huddy... full solid not hollow centres... custom made to your car at your house to what thickness you require
nigelswazi got it done... avs suspension have their number
gtr fit but are a tighter fit on the brackets due to being solid
https://www.sau.com.au/forums/topic/146963-swaybars/#findComment-2744809
well just had someone return a call who was looking to see if the s13 ones fit - they reackon they were on the phone to 6 different suspension places 'who have been in the business for 20years...' and they DONT fit. LOL. ok. my reply was - well these cars havent been here for 20 years and i know that they do fit and people have whiteline adjustable s13 swaybars in their cars :S.
end rant... lol
https://www.sau.com.au/forums/topic/146963-swaybars/#findComment-2746697
What spring rates you have again? was is 10/8?
I wouldn't be getting a 27mm front bar with those rates, or a 24mm rear bar. I'd say 24/22mm would be the go.
Whiteline swaybars are also solid. Hollow swaybars are better, but FAR more expensive.
https://www.sau.com.au/forums/topic/146963-swaybars/#findComment-2753594
thats right, its a common misconception that solid bars are better. Hollows have more resistance to twisting then solids. But yes, as salad said they are bloody expensive for what they are.
This is why GTR bars are such a good upgrade for the money, they are hollows and work really well.
https://www.sau.com.au/forums/topic/146963-swaybars/#findComment-2754381
Well not exactly more resistance. They are less resistant to torsional loads when both are the same diameter, but they are more efficient.
If you had 2 bars, 1 hollow and 1 solid of the same torsional stiffness, the hollow one will be around 30% of the weight. But the hollow one will have a much larger diameter to achieve the same stiffness, so then you start having troubles fitting them into standard D-brackets and much more expensive to make.
Hollow spring steal isn't available in a huge range of sizes, is more expensive and more expensive machinery is needed to manipulate it properly.
And there isn't much difference in brands of swaybars. They are all made from the same grade spring steal. The Japanese also get their spring steal from Australia :(
Edited by salad
https://www.sau.com.au/forums/topic/146963-swaybars/#findComment-2754887
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
