Friday Night Mountain Run - January
  • Replies 281
Posted Images
umm anyone have a free seat??
i got a spot in my lap for you troy :happy: but thats about it. have a look through the thread, there were a couple of people offering spare seats. i'm riding with oblivion, i think zennon was offering, cant remember.
i actually got my little brother coming with me now but you can always sit in the back :happy:
PS. Ian, probably a bit late now since you have already booked but yeah: will be ZENNON + 1 ;)
Edited by ZENNON
I AM SOFT Ian
Yeah I thought about it, I know my car well, but its not woth loosing brakes halfway down the mountain and hitting somthing when I already know the brakes aren't too good. The problem is that when I press the pedel it just wont stop. (well not like it should, not even close).
SOFT MAN
Have you bled the brakes properly? Sometimes that is the only problem
haha i tried that and it didn't work - so i roll started it - drove it to blurs place - and then when i got there it worked fine!! lol
so yeah - getting wheel allignment done now - (cos i installed lockbar)
and getting a little more camber too (going for -2 degrees)
summary: all is good so dont worry im coming!!! >_<
ps. HOORAY FOR DA BOOBIES
Pfft -4 or bust :)
wahhh! its tomoro!!
im so not going to sleep,
Ian put matt down as a mabey, he's pretty interested on getting some advice on his toyota celica.
plus he's my translator from, crazy car talk to blondish steph speaka
LOL @ man cleavage
Edited by ze_flexy_1
Pfft -4 or bust :rant:
Yeah Bunts, I took my car to ATS today and they replaced the brake fluid, they also told me that the rotors are stuffed and are too thinl to machine down. Now I am up for new rotors and pads for all 4 paws.
nah-hah ZENNON your made of wrong
enough spam now, sorry babe ;) love you long time
And yes, to be safe i cant wait, shall be fun fun fun
hehe i bought your b-day pressie today Ian hehehehehehehe i want to tell you but i cant!
*drools all over floor*
wait! :mad:
Stop making me spam! ;)
EVERYONE HAS TO BE THERE TOMORO OR I WILL MAKE YOUR NAME PRINCESS GHEY SISTAS
WTF?? Now you have said this, I expect the benchmark for QLD boobs on a cruise to far outweigh VIC SAU.... and the mark is high.
I better see puppies... haha!
how bout nnOOOOoooooo hahahahaha u suk
im afraid it will have to be the snow jacket on tomoro, then all the cleavage you'll se is your own! HA!
Sadly, i dont remember much boobs from teh 6 or 7 cruises and 2 events i have attended, well, boobs that i could look at without getting punched by someone ;)
Haha. Bit ghey.
I move a motion that 80% of member's fees should go to hired boobs!
well i know that the guy who owns/runs the soarer club here, he always turns up to cruises with atleast 2 models ;), his car was sponsored by sexpo or something, that had a soarer meet and everyone got to pose with the two blonde models and the car :mad:
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
