Thought I would copy the removing HICAS thread with this one. Had a look at it yesterday but I cant see how I can get to the air con pump as its at the bottom. And the belt that runs the pump is in the middle of all the other belts!
Does this mean i have to take the other ones off to take the air con one off or is there an easier way?
If someone knows of a guide let me know. Thanks people.
:laugh:
Edited by konect
https://www.sau.com.au/forums/topic/146978-removing-air-con/
one of the stagea guys is/was doing the same thing i think - there are diagrams in the FAST software or something from nissan with a bolt by bolt pics of assembly or alternatively to de-assemble it
Cool might rip out the old fast software and have a look.
Are you trying to take it off so you don't damage anything so you can sell the parts or are you just removing it cleanly?
If you're removing it cleanly then out comes the wrench, bolt cutters, gloves (if you're scared) and a whole lotta bending/pulling.
If you have a frount mount that'll probably have to come out to take out the condensor etc. Don't forget to bung where the pipes go into the firewall... I just used tape (worked good).
if you cant be bothered taking off the power steering belt to get access just cut the a/c belt, unless u are taking it off to sell... then i wouldnt cut it. also if its still gassed, and u rupture a seal it mite squirt in your eye and it will freeze your sweet sweet eye juices
Cutting sounds like the way to go. Dont want to sell the parts, just dont want to destroy anything else in the process.
    • I didnt present too many conclusions because I wanted your opinions and feedback based on your own experiences. I don't know the exact material, but it is similar to concrete and therfor only has valuable strength in compression. The forces on the set material once the head is removed would mostly be in compression since the grout wants to retain its shape and the block wants to return to its relaxed state since it's still within the elastic region. The grout would theoretically make the block more rigid. The exact amount would take a better setup on my end. Thought experiment: Instead of aliens, twist your favorite fleshlite. Now fill it with grout and allow it to sit for a week. Now try to twist it again. Observe what you see. Now get your other one and blow into it. Observe what you see. Now put it into a can and fill the space between your fleshlite and the can. After it sets blow into it. Less movement in torsion and less expansion i hope.
    • Hi. Yeah i think that DIS-008 should be ok too but i rather asked. The R8 coils are "sadly" no go for me cuz every solution is for forward plenum. The coils are too tall and one of the(4/5 DK) would not fit under stock J-pipe. And being this NA RB20 i dont even know where to get some forward plenum.(and of course i would need other stuff like custom AFM/ECU etc) and that is kinda non sense for NA without boost. I just looking for solutions for my case 🙂  I try look into those Yaris/Corolla ones.
    • Damn it, no, I topped up before I got to yours I really should look at Costco locations more when I'm out and about burning through fuel
    • Did you hit the one 5 minutes down the road from my place before heading back south? 😛
