Hmm, so mods are as listed in my signature. Basically changing from 1st to 2nd or 2nd to 3rd at about 6.5-7k rpm the car feels like for a fraction of a second it's starved of oxygen, and kind of jolts, then it jumps forward. It does it randomly, at different temperatures, not on every shift. Mainly when im shifting fast to.
I have a few ideas on what it could be, but i want other peoples opinions. thx
Mine does this aswell, but only when changing gears fast (it hesitates for a split second before power comes on strong).
I always put it down to the BOV not letting enough air out on gearchanges when the throttle is closed, stopping the flow of air to the engine for a split second.
That air then has to be brought back to speed once the throttle is opened after the gearchange, hence the slight hesistation before power comes on (lack of air speed initially).
I could be totally wrong though.
Fixxxer :laugh:
I was actually thinking on the contrary, that it was the BOV emptying too much air out (i.e. a leak?), that resulted in starvation after the change as the piping was refilled.
What your saying makes more sense.. maybe my BOV is on the way out, people say they are good to about 230rwkw normally
Anyone else?
Edited by 123456
A BOV doesn't effect the speed of the air on the way to the engine.
All it does is release pressure so that the blades of the turbo can keep spinning.
If you had a hose spraying water into your garden and you quickly stuck a hole in the side of it, you aren't increasing the speed of the water out the nossle.
How long since your re-map. Might wanna check out some tuning issues first.
Um about 2-3 months, and only thing i've changed since remap is the dump and a new cat, which didn't make the surging any worse, any other suggestions? Just feels like it's starved of air.. or fuel after change, could it be timing related or not?
To continue on from what I was saying before, and what I think happens is that the BOV will release pressure or 'boost' in the pipes after a gearchange.
After getting back on the gas again, the throttle is reopened, turbo shaft speed has also decreased by being off the gas (by how much I don't know), but the pressurised air that was in there just before the gearchange is gone/vented. The turbo has to then build pressure in the system, which shows up as a hesitation on quick gearchanges.
Therefore I think that a large FMIC setup with large pipes will exacerbate this problem.
Fixxxer
You are talking about turbo lag yes I noticed. Its not "stopping the flow of air" is what I was saying. If you think about it, with a less effective bov or no bov, the engine see's boost for longer, the only thing that is aided, is the speed of the impellor.
I'd be checking the AFR. You say yourself it feels like a afr issue. Thats the only way to be sure I reckon.
when you change gears quickly the bov doesn't have much time to dump air, so there isn't much of a pressure loss in the piping.
i'd possible point the finger at the boost controller. the air between the controller and the wastegate isn't able to escape fast enough, so the wastegate is still partly open when you get on the gas again, so you have less boost until the wastegate is fully shut.
Ah yeh, thats true, if changing quick it wouldnt have much time to vent.. Do you think it's worth getting a new controller then? Or are you saying boost controllers in general can cause this problem? The joint that tuned it seemed to think that they (Can't remember brand, they were $29, had a long topic.. turbosmart?) were pretty decent
Heres a dyno graph if that helps (before new CAT and Split dump)
thx
Edited by 123456
You need to be able to change the gears with out shutting the throttle... eg Flatchange!
And inless you want things to break I surgest not doing that inless you have a ecu that will allow you to do it also...
Or buy an auto!
Other than that you proberly have a fuel issue; tuning/supply
Edited by cameron
Is that a dyno sheet for ants?
Everyone is thinking turbo lag... I don't know if he is describing that. Jolts and feels like it starved... then jumps forward, sounds like something being too rich...
I still reckon check out the AFR's and see if its gone a bit silly due to a small problem somewhere along the line.
A atmospheric BOV vents measured air to the atmosphere. Your cars air flow meter has measured X amount of air in the system which requires Y amount of fuel. When people screw around by dumping the measured air out of the system - the car does not like it..... It still dumps Y amount of fuel into the cylinders.
Cheers
Sumo
the gtr was doing that for a while, just lacking power and stuttering under load. wasnt very violent, inet pressure stayed up, although the turbo's sounded like they were choking. it did it mostly when they would start to wind up. traced it down to a faulty O2 sensor...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
