Would something with modifications pictured below be eligible to come through SEV's?
The simple answer is NO because it's not totally standard - the current laws are that all cars must be completely stock for SEVS compliance, however in reality you should be able to import anything as long as it can be returned to standard without any signs that it was ever modified (eg. no holes cut for intercooler piping, etc.)
If you do import a modified car then you would either have to swap it back to standard yourself or make some arrangements with the compliance workshop for them to do it for you, most workshops will charge extra for the work involved unless it's only very simple and common mods like exhaust and allow wheels.
Obviously some care would be needed when buying cars with this level of modifications to make sure it's only mods that can be removed without leaving any damage on the car, so just make sure the car is checked very well and also make sure you get approval from the compliance workshop before buying, this will reduce the chances that it could be rejected once it arrives.
Thank you Craig,
This is Jarryd who rang about the GX71 last week, looks like it won't be happening as my mate was wanting to road register the vehicle but long nose conversion breaches at least 4 ADR's :ninja: Very grateful for your efforts and may still get back to you soon regarding another car on Don's Gallery
Does anyone know who has a compliance pack for the JZX81?
Yes they are... as a 'purple plate' import under SEVS
There is apparently a company with a compliance pack called ISHE(don't know what these letter stand for) west of Brisbane.... Yet to find anymore info on them
Nothing on the register, nor the RAWS search atm about RAWS eligibility or approval for an 81.
There's only one colour plate for SEVS, and JZX81 isn't one of them :(
Are you thinking of IMSHE on the Gold Coast??
I'm only going on the info I was given.. Is the place you speak of known for compliance work?
They are actually called IAMSHE and they are a SEVS compliance workshop, I am not sure if they do a lot of 1988 & older cars these days or not:
http://raws.dotars.gov.au/rawswebpublic/RA...cipant_id=10171
yeah just spoke to them and they don't do jzx81's..
Turning into a wild goose chase
Sorry, I should have mentioned that no workshops are able to do JZX81's at this stage, and I doubt any ever will due to a lack of interest compared to other models.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
