Hey everyone...
Have a few things for sale..All parts are in Brisbane, QLD. If your interested in any of them please email on [email protected].
Cheers Aliesha
R32 GTS-T Rear Spoiler = $60
Good condition, couple of tiny scraches underneath, break light works.
R32 GTS-T ECU = $70
Used but works fine.
Universal Pod Filter = $15
Used
HKS Power Flow Pod= $50
Used. Filter not inc.
Set of 4 Light Weight ENKEI Rims = $200 ono
15 x 7, 4 Stud, One Rim has a small crack but can be fixed by Tigweld
Some other Suff...
S13 Slivia Left Hand Indocatior = $25
Works Fine, One mount broken can be fixed.
CA18 Ignition Coil Pack = $15
Used Works Fine.
S13 BENDIX Rear Break Pads = $30
Never used.
Edited by Aliesha
Not to be rude but that K&N filter cleaner kit retails for $28.
lol thanks...that would be my partners fault he gave me the pics and a list of stuff prices and i just put it on here
Cheers
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
    • Some sense has prevailed! What kind of idiot spends money on intake, heads, and cams for a N/A motor in 2025? Lol. What maroons. Source:I am King Maroon.
    • So, cams are not getting installed......yet  Had a good chat with MX5 Mania about intakes, they recommend not to get ITB's, they recommend a plenum style for the NC So, one of these puppies is being ordered, with a larger TB to suit, when it arrives from the US the car will go in for the cams and intake I'm also getting a fancy rear box bit for the air filter box which will suit the new TB size
    • Clamp meter is pointless. Unless you're trying to keep average current under a set value for some weird reason (maybe you undersized your wiring?), then you'll get no useful info. What you're really trying to target is the flow of fuel coming back to the tank. You want some, but not a lot. You also want to make sure fuel pressure remains stable.   So, fuel pressure gauge, and fuel flow gauge. Set it up from that.
