i am building a cold air box in my 32gtst and was considering the option of a bonnet vent instead of feeding air through the front bar, would this mean i would have problems in rain ? was thinking out putting an R34 GTR V spec II vent on
gunna photoshop some pics to see how it looks but cant find any decent pics of the real thing :ninja:
anyways yeh, would water gt on my pod, and this would be bad right ?
https://www.sau.com.au/forums/topic/147027-bonnet-vents/
Rain is gonna get in what ever you do if driving in bad weather.
I'd go front bar vent...
1. Build a rain trap in the induction pipe.
Straight pipe tee'd or Y'd off to the air box,
dead end the straight bit of pipe about 6 inches awat from the T or Y
Water is heavier so wil carry straight on the easiest path.....i(e) the dead end.
It will hit the dead end,so put a small hiole in the dead end at the bottom edge to drain water away, via a drain pipe/ tube or just leave the hole to draining away to outside the body obviously
job done....
...some water bourne air will still carry on in to the airbox, cant be helped...bit like cheap water injection...LOL
2 or just plug the air inlet pipe in bad weather, and take the lid off your air box.....your not going to be road racing in really bad weather anyway.
Edited by Allkiller
https://www.sau.com.au/forums/topic/147027-bonnet-vents/#findComment-2745079
The Hood Vent looks very cool
But it is in turbulent air...as it hits the grill and lights air curls over the front and is not ram air style as the Front Bar would be,
The hood vent would need to be further back to avoid the turbulence IMO
https://www.sau.com.au/forums/topic/147027-bonnet-vents/#findComment-2745172
it may not get as much as a ram air fed system.
it still gets alot of airflow through that vent.. the airbox will seal against the bonnet and a custom pipe is going to be made that feeds air straight to my turbo's. as i dont need my AFM's anymore.. it is trial and error at the moment but i think it will be sufficiant.. gives quite an induction noise thats for sure...
*edit* yes water gets in if it rains...
Edited by Noy
https://www.sau.com.au/forums/topic/147027-bonnet-vents/#findComment-2745261
    • The interesting part of tests like IM240 is they measure the exhaust output. But they never measure the gases going into the engine... Imagine doing the test in a densely populated city with higher CO2 levels around... Instant disadvantage...
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
