i am building a cold air box in my 32gtst and was considering the option of a bonnet vent instead of feeding air through the front bar, would this mean i would have problems in rain ? was thinking out putting an R34 GTR V spec II vent on
gunna photoshop some pics to see how it looks but cant find any decent pics of the real thing :ninja:
anyways yeh, would water gt on my pod, and this would be bad right ?
https://www.sau.com.au/forums/topic/147027-bonnet-vents/
Rain is gonna get in what ever you do if driving in bad weather.
I'd go front bar vent...
1. Build a rain trap in the induction pipe.
Straight pipe tee'd or Y'd off to the air box,
dead end the straight bit of pipe about 6 inches awat from the T or Y
Water is heavier so wil carry straight on the easiest path.....i(e) the dead end.
It will hit the dead end,so put a small hiole in the dead end at the bottom edge to drain water away, via a drain pipe/ tube or just leave the hole to draining away to outside the body obviously
job done....
...some water bourne air will still carry on in to the airbox, cant be helped...bit like cheap water injection...LOL
2 or just plug the air inlet pipe in bad weather, and take the lid off your air box.....your not going to be road racing in really bad weather anyway.
Edited by Allkiller
https://www.sau.com.au/forums/topic/147027-bonnet-vents/#findComment-2745079
The Hood Vent looks very cool
But it is in turbulent air...as it hits the grill and lights air curls over the front and is not ram air style as the Front Bar would be,
The hood vent would need to be further back to avoid the turbulence IMO
https://www.sau.com.au/forums/topic/147027-bonnet-vents/#findComment-2745172
it may not get as much as a ram air fed system.
it still gets alot of airflow through that vent.. the airbox will seal against the bonnet and a custom pipe is going to be made that feeds air straight to my turbo's. as i dont need my AFM's anymore.. it is trial and error at the moment but i think it will be sufficiant.. gives quite an induction noise thats for sure...
*edit* yes water gets in if it rains...
Edited by Noy
https://www.sau.com.au/forums/topic/147027-bonnet-vents/#findComment-2745261
    • 6 foot 91kg.   Thanks Brett, ill have a look into them!   Whoa 197 haha, I'm about 182 but not that far behind you in weight. My back is probably a little wider than most people my size and weight so I would most certainly need the XL seat by the sounds of it.  The car is insured to drive 1000km a year (might up that at some stage) but it would likely take me at least 5 years before I would ever get close to 15,000km. If I don't buy the real ones I kind of feel like I'm cheaping out though lol Spent all this money on good quality parts every where else just to cheap out on the seats? probably my OCD.  I did find these guys who are more local to me and have copy seats in stock.  https://vosta.com.au/collections/reclining-bucket-seats/products/japan-stadia-ii-gradation Or if I want to go genuine   https://www.carmodsaustralia.com.au/brand/bride-racing/?srsltid=AfmBOooYKfh5btzB8-ezRTTokM0AqQ3GyWKcfutaMRWBzosRLNSFQhLt
    • Good. I was worried we were still talking about the block. Yes, larger baffled sump is a good idea. Do not touch the pump unless you're going on a whole build saga. Read the oil control thread on here - at least the last 100 pages or so. We drew some reasonable things together in there. The short version is that venting the sump is more important than almost anything else you do.
    • Perhaps just get a proper mechanic who is good with Nissan autos (they were more or less the same across all the RWD, FWD, 4WD cars at that time, even if they were actually different boxes) to give it a good going over. He might be able to plug in a Consult or other scan tool and find out if it's got some fault codes. Otherwise, my approach to the problem if not liking the way the auto was workign behind my RB20 turbo, was to drop it on the workshop floor and put in the manual box that it really needed. That solved all the auto problems.
    • Gotcha, I mean that is at least good to hear. Are there signs, or troubleshooting tips to make sure the transmission is operating properly?
