Best Size Intercooler For 300-320awkw For Rb26?
PhilGTR
 Share
For around 300-320awkw what size interooler would be best suitable for a rb26? I understand some people say that the stock cooler is good enough but I also would like to know what else could do a better job? Looking at running aroind 1.2bar boost. Is a 600x300x85 trust cooler a good size for the power level? And I have used the search button and would like more advice :/
Your spot on, the factory intercooler is ample for your application.
If you did choose to upgrade, changing to the Trust cooler you mentioned above would be a waste as it isnt much larger than standard.
HKS and ARC both make excellent bolt on upgrades for GTR - ARC is about the best you can buy and would be the way to go if your budget allows it.
I've got a PWR cooler and have similar power figures to you and have no issues with it. Quality is the best you could ask for. Not sure how much bigger it is than stock, I never seen a stock cooler ;)
ARC, end of story. You can't buy a better performing cooler period.
I went from Trust to ARC of the same size and the ARC just romps away in every way. 600x300x70 380rwkw gt2530's.
From the knife edged inlet channels to the flow through design to aid radiator cooling... My car overheated before...not now. I also picked up 300rpm less lag, bolt on.
not so sure it would perform worse. ARE are one of the best cores around, and they fab very nice end tanks. PWR and plazmaman also make very nice gear of the aussie made stuff.
an ARC core for your 32 should be around the $1800 mark delivered.
why would you pay ARC money for less performance......
i'd like to see a comparison of the so called 'high flowing' japanese coolers.
like i said - i would rather support the guys in QLD instead of a massive company in Japan, if it does the same or better job.
but hey, spend your money how you like...
Granted the ARC is of excellent construction but, so is the ARE. I am not privy to any back to back testing of ARC and ARE so I can't comment but, if you have no data, neither can you.
ARE have the plus that they don't have a one size fits all mentality that afflicts the jap brands.
ARE do a great deal of on-going flow bench research to get the most from the end tank design.
ARC are offering an off the shelf 'bolt on' , it has excellent build and design. The cons are limited selection of core size and end tank config. You end up with some compromises and unless you happen to fluke it with your setup it's unlikely you hit the sweet spot for overall design efficiency. You get a good improvement of course.
ARE can undertake a custom build around airflow requirements based on hitting an 'average horsepower' aiflow target. They have some tricks in endtank design they have developed to increase flow they can throw in too. Overall you get something 'aimed' at your specific application.
if your stocker is stuffed, just jap do a 100mm upgrade "bolt on" for $300 or so, they have gtr style end tanks which are quite good.
I have tried one of these, the tube and fin design looks ok however the inlet and oulets are the wrong size(3") instead of metric...
granted, I don't have back to back ARE to ARC, however I do have Trust to ARC(of the same size core). The design of the ARC core will flow better than an ARE or any other brand I have seen of the same size core IMHO...but hey like what has be defensively stated I can't prove that. All I have gone off is the experience I have had and the design of the Patented ARC core's. Best go do the relative web site and research for yourself. For the record ARC offer full customs configurations....you have obviously not done your own research.....
As for fluking my setup style......lol, no fluke...... thats the reason people buy ARC the are tried and proven...
I feel what it comes down to....petty bickering aside.... ARE offer a product that is local and cheaper, which I believe to be similar quality to some Jap brands. ARC is definately more expensive and harder to get. In my history I have owned 36 cars most being turbo charged and intercooled....in my experience I have personally found ARC to rival all others.
 Share
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
    • People just don't understand how good MX5's actually are and how fun they are to drive, park, manuever. You feel like you have got some fun cheat code, while everyone else is sitting in their luxobargeSUV like normies who missed the point of living. It really is that noticable. As long as you/your stuff fit, and you're comfortable (they are), a MX5 is the best car on earth to daily around.
